New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
Nihilanth
"I think it's better to have ideas [than beliefs.] You can change an idea. Changing a belief is trickier. Life should malleable and progressive; working from idea to idea permits that. Beliefs anchor you to certain points and limit growth; new ideas can't generate. Life becomes stagnant." - Rufus the 13 Apostle.
EMdevices
Yes,   the "genie" is finally "out of bottle" (neck) and running in "closed loop"  producing so much electricity that Ali doesn't know what to do with it all.   A very luck man indeed.   ;)
Happy New Year to all,
EM
nightlife
 I should have spent more time thinking about this before replying before. It reminds me of a design I had for a bedini that I posted a couple of years ago. It uses a both poles of a magnetic field and switches the field back and forth between each to keep from permanently magnetizing the core and by doing so it collects the energy from each flush as well as the energy gained from the free movement that is created.
This sounds like what is done here. The energy used is being switched back and forth requiring very little energy to keep keep switching because the energy is not being allowed to escape. It directs the energy in one direction and then back in the opposite direction and then over again and so on. Very little energy is lost and much movement is created. Kind of like dumping a cap into a coil and then dumping the coil back into the cap. Each move creates an opposite magnetic field and the field is created for very little cost after the first amount of energy is applied.
EMdevices
@nightlife
the "genie" is  a lot more simple then it is made out to be.   The fast switching represents a high frequency that is filtered by the watt meter, which is designed for 60 Hz.   The "extra energy" is not free energy, but rather it is energy that is not being recorded by the meter under these fast switching conditions.   Ali is so full of it, when he says he has "closed loop" operation, I don't belive him at all, unless perhaps he means something totaly different by the expression "closed loop".
EM
gotoluc
Quote from: EMdevices on January 01, 2010, 05:28:30 PM
EM
Hi EM,
so far I see Ali as being a genuine person and helpful in sharing what he can at this time.
Fact is:
Your assessment if Ali's possible method or circuit is not FACTUAL since Ali has not shared his circuit yet :-\... your assessment is based on how you believe Ali maybe doing it.
I don't get involve in debate with members but when you say someone is full of it without the FACTS ???...this is a negative comment based on your personal belief!... so don't you think it's possible that you could be full of it?
This is for you to think ::) about!...  like I said (I don't get involve in debate) I'm only interested in putting my energy in alternative free energy solutions to freely help those in need.
Many people don't realize that the mass of the World's population is living in poverty and are totally helpless. We are not!... so working together is the only way we can change this World to a better place :)
Sincerely
Luc
