New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
robbie47
@ Ali: I noticed a second input line, indicate by the red arrow in the attached picture.
What kind of input is that? Is it 12 V DC?
winsonali
yes this 12 volts 250 milli amp (0.25amp)   DC for circuit
Goat
Quote from: winsonali on September 01, 2009, 01:23:58 AM
hi mark,
"you are increasing voltage but reducing current"
REPLY:always remember you can provide voltage to some load but the current is defined by the load it self
explaining further: in a 220 volt socket you can plug 1000 watt heater it will draw 4 to 5 amps
at the same time if you put 100 watt bulb it will draw 0.5 amps approx.
so voltage is provided , current is the drawn from the line according to the load.
in watt meter voltage coil only open the path for magnetic flux but current coil make the movement to see how much wattage is being consummed.
in my device i am providing it 30 volts
when we conduct a test of 160 watt  at output source of our device it was giving us 220 volts at 0.7 amps approx.
and when we check the current at the input the voltages are 30 volts at 1.5 amps
RESULTS:
input  =     30 *1.5 = 45 watt  (in a simple approach not going in complexity at the moment)
output = 220 * 0.7 = 154 watt (you see amps gone down from 1.5 to 0.7 this is very natural)
Now with in the device the switching is in a very specific way, causes a resonance and more charges aligning themselves then in a conventional manner
telling you truly when i was conducting these tests i was knowing that charges are there but they are not in flow and i have to find a way to make them flow or convert them as workable PD(potential difference )
mechanical example of situation: you have bath tub full of water the top is open water cannot flow out from top  if you make a whole in bottom of the tub it will flow (natural) now i have to make water flow from top. if i can do the same in electronic means what i have achieved is creating PD with non aligned electrons.
i am in the middle of writing the thesis about my theories and there practical conversions so i will not discuss these concepts any further until i arrange to publish them
i am not saying that i am a very intelligent man but i am learning as well an argument for  argument will waste our own time rather then a simple practical output if my device is working and have potential soon it will be there in market its just a matter of time
i think my idea to givel the unit for R@D purpose to get hold of some funds as donation to noble cause to further carry out research was not a good idea
coz according to my professional ethics i will not give unit to any one until he is satisfied and knows what he is getting
and people around me are not able to digest the new concept here, i should carry on my work and take it to a completion level
strange enough no body asked me ,what is the next level in development if its working why not i start producing it
the difficulties;
the behavior of the unit is purely like a generator you off load it, the  voltage rises we need to develop an AVR
loads like air conditioners turns on the compressor and turns off this could seriously effect the process, an instantaneous response to load variation is required to be incorporated with in device
device cannot work without load it will destroy it self (resonating frequency) we need to include dummy load to balance the device and harness the appropriate output according to current dissipation.
if output load increase from the capacity of input source the unit destroy it self
things are not so simple as it seems, a lot more work is required before the device is ready for market
i posted the video on you tube when i saw magna coaster video, i did wrong i should complete the device by burning more of my own fuel to reach the destination , rather then giving people half cooked device i think i should get hold of some project to make enough money to complete my unit then sky is the limit.
thanks to everyone
Ali
Sorry guys for the long quote I screwed up there...but I think Ali touches on a lot of good points.
Ok so the device is maybe not ready for prime time but the principles involved are none the less interesting.
@ Ali
Could you feed the 12 Volt input to the device and run a 12VDC/120VAC or 220VAC inverter for the 30VAC on the circuit and get the motionless generator to produce the 220 * 0.7 = 154 watt you mentioned earlier?
If you can run the device on only the 12 Volt battery and show OU on a single battery as far as I/P vs O/P then you'd convince everyone on this thread, I think!
Paul
robbie47
@ Ali, what is it that you seek in this forum?
I think many of us are willing to help you out with remaining problems.
If you want us to help you with this device you need to explain some more details of your converter, I am afraid.
Otherwise you will get a lot of scattered questions.
winsonali
robbie47
I made good friends over here on this forum all of them are working for a single cause to provide fossil fuel less energy ,energy that do not contribute to entropy a clean air for breathing at last green should prevail the era for fossil fuel should finish war for oil resources should come to an end
all this is possible with free energy
Paul i have started working working on DC based unit it involve a technical aspect, that my unit takes only supply with +ve and _ve say +12 volts then -12 volts in same wire (true A/C) other wire should be a neutral return path, otherwise we will  not be able to achieve siphon
any way i think i have open a new door for acquiring energy
any body on forum looking forward to design any mechaical aspect of life in electronics can ask me and i will do it
thanks
