New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
100 % agreed with micro volts at antenna
process of PM manufacturing is based on cooling the material slowly/naturally in magnetic environment
once it is cooled to ambient temperature that magnetic force remain there for years
very simple you cannot define the relationship between energy required to make a permanent magnet and  force available through that magnet over the years how you will explain law of conservation of energy here.
lets take a look at ohms law:
V directly proportional to  current
V=I R  (R = ratio adjuster for proportionality)
now if something has constant resistance it will dissipate constant power in other words
if resistance is constant then power will be constant provided you are not changing voltage.
now
P=V*I
or v = P/I (remove the constant power)
V is inversely proportional to I
the above statement is true means how many calculations were wrong
mathematics is the poetry of science writing it correctly is an art
laws are man defined there could be flaws in them but they are  mostly correct.
now this is my theory..
once any energy released from its active zone to its passive zone it moves freely and travel in all directions can be experienced equally in a certain area without losing its powers.
winsonali
QuoteOne could use a single tuning fork to resonate with multiple other tuning forks, getting the same output for however many tuning forks there are. A bunch of PZT tuning forks would be a rather noisy overunity device.
Nilihanth:
this is the most perfect example of forces behavior in passive medium.
winsonali
QuoteHi Ali, can you explain what you mean with 'release from its active zone to passive zone'?
Maybe you can give an example?
teslaaset:
active zone is the medium where you can apply effects by interfering and mixing of signals
for instant with gain control you can increase or decrease the power of a transmitter but once the energy released in passive zone you cannot do anything with it
in air infinite radio electromagnetic fields are present you can feel them but cannot alter them until and unless you capture them in active zone.
gravityblock
Quote from: jan.kolar on November 24, 2009, 04:55:47 AM
According to wikipedia article div B = 0 so classical theory is valid.
div B = 0 is derivable from the Biot-Savart's law.
If a true monopole exists, then div B is no longer zero and a Coulomb-like term would have to be added to Biot-Savart's law, but Biot-Savart's would still give the B field of a current.
The end results would be the same weather we account for the monopole or not in B-S law.
div b = 0 does not mean monopoles do not exist!
Nihilanth
Quote from: winsonali on November 24, 2009, 06:32:58 AMthis is the most perfect example of forces behavior in passive medium.
Thank you. Joke-devices aside, what exactly are you hinting at? Am I correct in assuming it has something to do with capacitor or inductor resonance?
"I think it's better to have ideas [than beliefs.] You can change an idea. Changing a belief is trickier. Life should malleable and progressive; working from idea to idea permits that. Beliefs anchor you to certain points and limit growth; new ideas can't generate. Life becomes stagnant." - Rufus the 13 Apostle.
