New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
Cap-Z-ro
forest...for not being an EE, you seem to have a broad base of knowledge.
Something occurred to me when you wondered is Tesla was purposely misleading.
I wonder if you just reversed his 'directions' wherever possible, would that be the key to truly understanding his patents ?
Regards...
forest
Quote from: Cap-Z-ro on November 27, 2009, 06:42:13 PM
Regards...
How so ? I don't understand you. Do you state that Tesla has spoken using some code and we should read it "in reverse" ? I don't think so.
Entering into passive zone means unidirectional transfer of energy - nothing is lost ,nothing is reflected back. Now, that require ambient background as a carrier. This is how I understand it and I feel it's not far from truth.
Imagine a swing and you on it.Then somebody is trying to stop swing and you have to work harder to sustain oscillations. This is active zone and lenz law and the person trying to stop swing is the load.Resonance is destroyed.
Now imagine that you have magic ball in hands.Whenever you are at the top position of swing you throw that ball away by using swing kinetic energy nothing more.Just before the peak, the 1/4 of period of oscillation.Resonance is  not interrupted, ball is thrown away and accidentally you may even got a force back which strengthen amplitude of oscillations.
Ball is now in passive zone and can make work around. Look , because it is now unidirectional energy transfer.  Of course that magic ball has to be recreated now. This is not overunity yet. This is 100% efficient system with unidirectional energy transfer.
That's why I said at start that pushing total energy of primary into secondary makes difference. Whenever you have unidirectional energy transfer you have efficient system and half-open gate to overunity systems.
forest
winsonali
wattsup:
Genie has an output just like an inverter where both wire show live currents means if you take a tester and check the source with ground you will find both the wires are active.but when you check the same thing at main source in you home you will get one live wire and one return on one live wire you will get both -ve and +ve due to this reason e cannot feed back genie during process of testing i with the help of a physicist and electronic engineer discover high current spikes in genie and now we have recovered that problem by adjusting switching timing this has changed a lot of results, Now all this effort i am putting in to developing a method or power supply which can work same as live wire and give you output then i can re loop the output and produce self running system.
Forest:
i am using 2.4 GHZ in ISM band with no return to ground
always remember if you get spark or flair in any electrical transmission it means it is high voltage not high current and this high voltage is unable to get the proper exit from conductor so it is coming out with pressure and huge lose. if its a proper gate means antenna of proper wave length it will convert into EM waves and it will not make an spark or plasma.
well i have to proof my concept with practical which i have achieved up to an extent
difference between active and passive zone is very big.
and example of passive zone.
one thing more if you have room with mirror from all sides and you lit the light bulb you will find a lot of brightness and increased luminescence does it means you have increased the power.
Now if the same room is painted black you will find a lot less brightness as well as low luminescence
another example when you go out in sun light at a normal temperature of lets say 30 degree centigrade it will not burn you for example on beaches you can find hot babes taking sun bath..
now if you take a small lens and focus the reflection of sun  on a wood or paper it will burn.
its up to us how we observe things and can use them in our daily life.
Tesla has his vision and i have mine lets see . .. now i have to proof myself with practical by completing this system.
in my next post i will put the brochure of my inverter.
winsonali
forest:
Quotemeans unidirectional transfer of energy
no this is not uni-directional its omni directional.
i must say you have broad vision by putting the example of swing...
the amount of energy required to create a PM and the amount of force it will release in years is itself an example of a method where you initiate a process and it will last for long. we are trying to find that method to produce electric charges in the same manner.
now you discuss lens force, every body give definition of lens force but never give the reason
lens force is the force produce in opposite direction when a current flow occurs in a conductor..  this is observation not the reason if we find the reason we can control it
now i want you to explore the reason then i will give my analogy.
