Bedini SSG - self sustaining
Started by plengo, August 28, 2009, 08:04:34 PM
plengo
@all
ops i just notice I mistyped 100v instead of 10volts spike on previous post. It is 10 volts spike NOT 100 volts. Thanks to gyulasun to point that out.
Fausto.
Magluvin
http://www.youtube.com/watch?v=B7QIpfSX_4Q
A vid of the reed in action. I am running 2 of the big coils in parallel with my regular green one. 0.4 ohm total load, and the 4 AA are at 5.13v running.
It was just some of my first runs testing the reeds. I like them.
Next tests will be the bifi comparisons, they are 2 ohm each
Mags
Magluvin
http://www.youtube.com/watch?v=YeqXJAcLw8c
As last vid but got it going faster
http://www.youtube.com/watch?v=OJ0LYpMH41E
Added a larger polarizing mag and yet she runs even faster. Sick!!
I know top speed is not a goal here, but for now its fun. =]
Mags
mscoffman
One experimentation idea is to use an "Audio Transformer" line-to-load transformer
to step up voltage pulses for charging batteries. It would allow one to have a
much higher voltage charge pulse without needing dozens of batteries to generate
the pulses via capacitors. I keep remembering an audio transformer with a lot of
closely spaced secondary taps, to kind of trim the overall volume of an independent
loudspeaker.
An audio transformer; because the frequency response would be in the 100Hz -> 30KHz
range, which it what we are talking about here, without needing a RF pulse transformer
with specialized core materials.
:S:MarkSCoffman
plengo
@Magluvin
beautiful work. She is spinning indeed. You are totally doing Adams motor with success, I am totally impressed. Today I went to ebay and tried to buy some big reed switches too. I can barely wait to replicate your work.
How much voltage are you using to run your setup? And is this diagram still what you have? What are the magnets you are using?
Pretty cat too. I have 2 myself.
Fausto.
