I see an economic diasater coming...
Started by the_big_m_in_ok, September 03, 2009, 01:05:30 AM
Do you think the American economy will ever improve?
Yes, definitely
Possibly, in the long run
No, it will worsen
Undecided
triffid
Its amazing to see what junk lies in the backstreet alleys here in st.louis.Old tires for instance.triffid
triffid
I see lots of bicycles being used here.I guess with the higher gas prices coming its a smart move to get one.As long as your trips are about 5 miles or less?For the really hardy people trips of 10-15 miles would be practical.Of course the very weathly would buy gas no matter what the price.triffid
the_big_m_in_ok
Quote from: triffid on June 03, 2011, 06:34:50 PM
With respect to Replies #117, #118 and this one above:
    I never tried to cook outdoors when I was on the streets, since the smoke could have been seen and reported as a "wildfire" or "range fire."
Good you're being self-reliant.  Bikes are dangerous in the extreme here in S.F.  Expensive, too.
I've been putting more time on me bench threads at   http://overunityresearch.com    near the bottom of the home page under the same handle name I use here.  Anyone can go look for mouse-clicking on the 'Web address.
--Lee
triffid
Here is some of the negative info on the testakita device that I found.
I may have been wrong in saying it generates positive ions.It does take static electricity out of the air.as I will never build myself.I don't care too much but it does say it attracts thunderstorms.
15.9 The Testatika
An electrostatic device, which produces open electric field lines, is situated in Linden in
Switzerland. It optically is very imposing and belongs to a religious community, which
has called it Testatika and is of the opinion that it is a free energy converter.
Inexplicably the Testatika does not serve the community, which generates their electric
power conventionally and to a large extent by itself, as a source of energy. Instead the 2
kW device only very seldom is demonstrated for special occasions or to select groups of
visitors. The religious community after that explains the astonished observers humanity
not yet is mature for the technology.
Perhaps just the opposite is correct and the technology not yet is mature. According to my
personal assessment such an electrostatic device in principle is entirely unsuitable for the
continuous operation.
It can be expected that the open field lines sooner or later will interrelate with the
electricity of the air and thunderstorms are being attracted by the infernal machine so long
until lightning strikes and the demonstration with that has finished. That's why the
Testatika may be switched on only for a short time, only at sure weather situation and not
too humid air, and many a registered visitor has been sent away without having seen the
"thunderstorm machine".
As an object of demonstration and study the Testatika however is well suited. Alone the
circumstance that no cable leads to the device and it nevertheless releases energy in the
order of magnitude of 1 till 2 kW, surprises all visitors. At least the impression is mediated
as if the machine would violate the law of conservation of energy, which is not correct.
The Testatika is similar to an induction machine, which works with friction electricity.
Thereby the unlikely charged bodies do not have to unconditionally touch and rub at each
other, it already is sufficient, if they are brought in the immediate vicinity of each other. In
the case of the Testatika the electrostatics of two against one another rotating discs is
taken off by brushes.
The excitation energy presumably is taken out of the natural E-field, which just like that
can amount to 200 Volts per meter (see chapter 2.9). The large diameter of 80 cm of the
discs and their bad conductivity (acrylic glass) permit this conclusion. The charge taken
off by the brushes afterwards is temporarily stored in two capacitors of 2 Farad at 300
Volt, so-called Leyden jars. This far one actually is reminded of a Wimhurst generator, in
which the energy is supplied the system by turning the disc. Large powers cannot be
drawn by that. Plans to build such an induction machine by yourself have been
published.
In the case of the Testatika however two discs are used and by hand stimulate to rotate
oppositely. This rotational energy in this case isn't used to produce power, otherwise the
discs quickly would stand still again, but that doesn't happen.
Until now apparently no-one has discovered the secret, which is kept strict by the
members of the community. In my opinion the energy situation on our earth however is
too serious, as that we would be able to afford playing hide-and-seek and egoistical
secretiveness.
15.10 The secret of the Testatika
The crucial point is the opposite direction of rotation of both discs. If we assume the static
earth electric field is the cause and serves as an excitation field, then as an effect a field
arises, which stands perpendicular to that. The axial component now points out of the
centre of the disc.
In the case of only one disc the field lines in front and behind the disc again are closed, so
that no open lines can form. With one disc or with two discs rotating in the same direction
hence no unknown charges can be attracted.
In the case of two oppositely rotating discs however shows one component along the axis
of rotation to the observer, that of the other disc exactly in the opposite direction. In that
way between both discs a pole is ,,pinned", which no longer is able to close all field lines
on the outside around the machine. Thus open field lines and a, however incomplete,
unipolar arrangement are formed.
The charge carriers sucked from the electricity of the air as a result support the natural
electrostatics and speedy recharge the capacitors, even if up to 10 Amperes are taken out
by the consumers.
The ingenious thing of the machine is its extremely simple construction and the simple
concept.
If one includes the collected particles also in the balance sheet of energy, then it thus will
turn out that the law of conservation of energy is not violated at all. There thus can't be
talked of free energy. In this context the Testatika may rather be given as a
counterexample. Air ions are the carriers of the electricity of the air and not carriers of
free energy.
Negative air ions are indispensable for our welfare. One should only remember the first
men in space, who after the landing were pulled out of their capsule more dead than alive,
after they had to stay in the unhealthy atmosphere of the capsule for a longer period of
time. Only the installation of ionising devices for negative air ions made possible longer
staying in space.
The taking out of the air of negative ions hence is not unproblematic and not particularly
ecologically compatible. An atmosphere harmful to life is formed which Dr. Wilhelm
Reich has called DOR-state. He by the way has designed a Cloud-Buster, with which he
could take static electricity, forming above the desert sand, out of the air. In that way the
negatively charged rain clouds no longer are repelled and driven away. Reich has tested
his weather machine 1954 in the desert of Arizona. After he had freed the atmosphere of
the ,,DOR-strain", as he expressed himself, in the desert area the atmospheric humidity
steadily increased from 15% up to 95%, there grew prairie grass and everything started to
turn green, and eventually after many years for the first time rain fell again.
Static electricity, as far as the right polarity is chosen, may conditionally be used for the
mechanics of rain making. For free energy concepts it however isn't suitable. Already
Nikola Tesla has pointed to the circumstance that our hopes will be in vain if the free
energy would be of static nature (see fig. 9.5). He in his speech, which he gave 1891
before the AIEE, has left no doubt that free energy exists, which is kinetic and with that
energy technically usable for us,.
Chapter 16 will be occupied solely with this case.
gauschor
Interesting article. About the Testatica - the line which said 1 disc will not allow this effect - is wrong though, because the small Testatica had only a single disc.
Regarding Wilhelm Reich: I have read about this machine which produces rain and thunderstorm in short time as well. Also some of these events (sudden thunderstorm) were mentioned for specific UFO sightings, especially after World War 2 or so.
