I see an economic diasater coming...
Started by the_big_m_in_ok, September 03, 2009, 01:05:30 AM
0 Members and 19 Guests are viewing this topic.
Do you think the American economy will ever improve?
Yes, definitely
Possibly, in the long run
No, it will worsen
Undecided
the_big_m_in_ok
Quote from: onthecuttingedge2005 on September 03, 2009, 11:29:16 PM
this is the current trend on a national rate and not by state. ...
Unemployment rate percentages over the years. ...
... lot of people tend to stick with one area now a days and lose out on the benefits of migration.
Jerry ;)
(The above quote is from Reply #4, pg. 1, this thread.)
I agree with the lack of migration.  It used to work for me back in the early 1980's, but not now.  It's a waste of time and money traveling now.  Every part of the country is hurting for jobs.  It's that way in AZ and CA.  I've been in both states in the last 3-4 years.
--Lee
triffid
Some details how past nuclear explosions and how the weather dispersed the isotopes.
http://www.sciencemag.org/content/155/3768/1405   triffid
triffid
04/11/11 - How oven rust could be the key to unlimited fuel that will power anything
Rust from ovens could be the key to making unlimited amounts of cheap fuel that could power anything, scientists have discovered. A team used ceria, which forms when ovens are heated, to strip oxygen from water and carbon dioxide and leave them with the basics of a liquid fuel. They said that potentially this fuel could be turned into cells which could power machines or converted into a natural gas for a generator. The researchers used ceria, which is the oxidised form of cerium and forms in self-cleaning ovens, to make their discovery. The first phase involved heating the ceria to 3,000F (1,650C) using concentrated sunlight so that it naturally released oxygen from its surface. When the temperature was lowered the researchers observed that it sucked oxygen in - as if it were ‘inhaling or exhaling’ depending on the temperature. When the researchers added water and carbon dioxide and lowered the temperature, the ceria stripped the oxygen away, leaving hydrogen in place of the water and carbon monoxide in place of the carbon dioxide. Hydrogen, or H2, and carbon monoxide, CO, together can be used to make fuels. Professor Haile, said: ‘You could use the H2 and CO to make methane (natural gas) for a gas-fired electricity generator. ‘Or, because the fuels we produce are so pure, they could be easily used to run fuel cells, which generate power very efficiently.’ She explained that because cerium is 100,000 more plentiful than platinum, which had been used in previous similar experiments, it made the process much more affordable. She added that more tests need to be done to make it more efficient. ‘As a second step, it will be important to develop materials with even better characteristics than ceria,’ she told Physorg.com. ‘Ideally, one wants a material with a smaller temperature swing required as this will also increase efficiency. - Full Article Source
triffid
The above post  might be the way to create unlimited amounts of methane very cheaply.triffid
triffid
how to make a smokeless fire and other neat tricks like how to make fire with compressed air.http://chrismolloy.com/www/p136  triffid
