Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
Howard and Ladies and Gentlemen:
You really have to look at all angles before you claim victory.  All that you are looking at here is the equivalent of a child shifting his weight on a swing so that he can swing higher and higher.  Howard's rotating servo mechanism is the equivalent of the child shifting his position on the swing.
Therefore, the energy source that is making the oscillator swing higher and higher is the battery pack that is affixed to the pendulum.
Here is the test that Howard should have done to double check his results:  Remove the magnet array and start the pendulum and make the servo system go back and forth just like he does in his clip.  You will see the pendulum swing higher and higher, confirming that the moving servo itself is what is adding energy to the swinging pendulum.  What is making the servo go back and forth?  The answer is the batteries.
The reason the pendulum swings higher and higher is because chemical energy in the batteries is being transformed into more mechanical energy being stored in the swinging pendulum.
You guys have got to put on your thinking caps.
Quote from: MileHigh on October 27, 2009, 07:34:55 PM
I partially agree. It's not a battery pack it's the magnet itself. To get rid of this argument it should be centered or even moved to the other side so that it technicality loses energy every cycle. But that doesn't explain the previous video which was centered  ;) .
spoondini
@milehigh,
     Good observation. I watched the video again and the megnetic array is not perfectly centered, this could indeed be the cause of acceleration.  The center of gravity does appear to shift.  My jury just went back to deliberation.  I've been meaning to make a 1/100th scale of this thing, pure mechanical to validate but time is hard to come by.
markdansie
@spoondini,
I got your message but computer froze everytime I tried to reply. Easy to email me markdansie@bigpond.com
Kind Regards
hartiberlin
Well, very good !
Congratulations !
Can you get the energy out of the magnet array at the top via coils to turn the drive magnet to get rid of batteries all in all ?
Then it would be the real breakthrough, if you could show this without batteries.
To turn the magnet by 180 degrees should not take much energy and could probably be made also mechanically somehow..
Looking forward to see an update.
I will put this onto the news.
Regards, Stefan.
