Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
Cloxxki
Thanks for your answers Howard.
I am most impressed with what you seem to have accomplished already.
I wish I could walk next door and make my hands dirty to help you out, sweep your floor even if that would help you work better.
All the best, keep the updates coming, and keep safe.
J
WattBuilder
Cloxxki,
Thanks for offering to help and for realizing that I’m doing this alone.
The hard part is over now as I’m in the phase now of trying to get as much people to understand as possible.
Cheers
Howard
WattBuilder
@All
Here’s my update.
I have now made the decision to put a hold on using the tail vane method to orientate the drive magnet. It’s taking me longer then I have planned. The things that I am running into going this route are lack of access to better materials and better tools.
I know that there are going to be some readers who will have a harder time understanding when I revert back to the use of the servo method.
The full understanding of the ability to scale and its effects is something that one may have to figure out. As my knowledge came from working in the field of the Automation Industry. I will do my best to help those understand.
For now I want to clear up the “step” function of my drive magnet’s position. Before I put up additional videos of the YOG.
You may have notice on my previous video that the drive magnet is offset from the centerline of the lever. The reasoning for that position is to allow for the step in a cycle to take place while also orientating the drive magnet. This function allows for “walking” or “climbing” how every you like to view it.
This makes it possible to add on top of the gain kinetic energy. Resulting in the lever getting lower and lower and the weight lifting higher and higher.
One can compare it to traveling up a flight of stairs or a truck bumper jack lifting a car.
It would be great if the magnetic array has a knob where you can turn up the magnetic energy for every cycle pass, but apparently magnets aren’t made that way.
The value of energy from the magnetic array is fixed. Depending on your array set up. So that’s why we need to add the “step” function.
Hopefully in the coming days I will be posting a new video where you can see the YOG in action with a servo.
Howard
My one cycle video http://www.youtube.com/watch?v=gekDM8vg16k
spoondini
Good luck with the servo method Howard.  I think you made a wise decision to go with a method you are confidant you can make work (perfection is the enemy of the possible).  If you use a servo but can still demonstrate continuous acceleration until load is attached, you will have convinced me the concept works (not sure how much that matters).  Best wishes.  Like cloxxki I also wish I could physically help you as your device shows promise.  Following your updates closely, thanks.
WattBuilder
Spoondini,
I think you will like this next video then.
Cheers
Howard
