Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
WattBuilder
@PowerCat
Quote from: WattBuilder on October 27, 2009, 11:25:45 PM
As far as the child shifting the weight? It does to a point but, for the child to gain higher and higher swings.
Quote from: WattBuilder on October 26, 2009, 11:39:45 AM
For now I want to clear up the “step” function of my drive magnet’s position. Before I put up additional videos of the YOG.
You may have notice on my previous video that the drive magnet is offset from the centerline of the lever. The reasoning for that position is to allow for the step in a cycle to take place while also orientating the drive magnet. This function allows for “walking” or “climbing” how every you like to view it.
This makes it possible to add on top of the gain kinetic energy. Resulting in the lever getting lower and lower and the weight lifting higher and higher.
One can compare it to traveling up a flight of stairs or a truck bumper jack lifting a car.
It would be great if the magnetic array has a knob where you can turn up the magnetic energy for every cycle pass, but apparently magnets aren’t made that way.
The value of energy from the magnetic array is fixed. Depending on your array set up. So that’s why we need to add the “step” function.
Howard
YOG Gain Video  http://www.youtube.com/watch?v=Cq5r08eqgsk
WattBuilder
@All,
Here's a drawing about what I think Stefan was talking about.
spoondini
Quote from: WattBuilder on October 28, 2009, 01:46:15 PM
@MileHigh
Your still blocking out the energy gain from the magnetic array. Even if you can argue your way to an “energy natural carrier” the energy gain from the magnetic array is still there?
That’s the real deal MileHigh â€" Your best argument will not come close to disproving energy gains from the magnetic array.
Howard,
   As excited as I was that it appeared you gained energy from magnets, this is scientifically impossible.  Please don't take this as negativity, just the same level of questioning anybody trying to validate your work would ask.  I also 'see' what milehigh is seeing.  I could make such a pendulum with continuous acceleration without the magnets with a seperate source of power continuously shifting the center of gravity.
I might be eating my words if this ultimately works(which I hope it does), but the magnetic forces should ultimately balance out, just like gravitational forces.
I've seen a thousand examples of what appear to be unidirectional torque applied by magnets, however nobody has EVER made the wheel continue spinning.  I will concede that I've never seen your approach, so maybe it will work.
Now I really need to see it without a shifting center of gravity coupled with continuous acceleration for my jury to finish their deliberations.  (my oppinion + $1 will buy you a cup of coffee at mcdonalds).
hartiberlin
Yes, Howard, simular to this,
but you could also use a generator on the wheel axis
to generate some DC power to power your servo
or something simular.
You have to pay attention to that the coils
in your example don´t break the movement too much due
to the Lenz law dragg.
Looking forward to see more videos from you.
Many thanks.
Regards, Stefan.
WattBuilder
Spoondini,
“It does to a point” that’s what I have been posting.
The offset acts like a “step function”.
Say you use energy to lift your legs up and down. You do not advance until you place one leg forward.
The YOG advancing is only needed for the circumference to turn the turbine longer.
So lets take your energy and assign it a value “S”. Now add in the value of the magnetic array “M”. Now the total YOG energy is now “SM”
Now what MileHigh is having a problem at is that he is not adding in the “M”. Also he is viewing the YOG as an “energy neutral carrier”. At best just transferring energy over, the “S”.
The energy loss is due to many factors like load of the turbine, bearings, air and the imperfections. Lets give that value “L”.
If “LS” is less than “M” then you have Overunity.
The value of “M” can always be increased just by getting stronger magnets or a better array set up.
Howard
