Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
exnihiloest
Quote from: WattBuilder on September 18, 2009, 05:08:52 PM
exnihiloest,
There is a combination of different features of the YOG that makes it possible, some are:
Lever, Pendulum, Counterbalance circumferenc...
The time of travel through the magnetic array that will allow the YOG to generate electricity during travel.
Basically time of consumption is less than time production.
We’ll if you look at it that way ?
Then it’s back to what MileHigh pointed out about an energy-neutral “carrier”.
More out then in.
I asked for measurements or at least calculi, not for blah.
So if we are not in the domain of science, but in that of faith, you can count me out.
   Free Energy is still achieved.
Yes of course. And Allah is great as others say with the same certainty.
WattBuilder
exnihiloest,
Leaving so fast?
You already made up your mind, in the beginning anyway. You did not ask for measurements or calculi. Check your post.
Seems like you entered in bashing without open to hear the science.
Besides, who are you to make any demands?
Nevertheless, I believe my invention has merit and I owe it to the generations that will fallow, to be aware of this method.
Is their anyone reading these posts see the merits of the YOG?
Howard
WattBuilder
For those of you who want to calculate the physics and math for yourselves. You can compare a “see-saw trebuchet fix hinged”, to one cycle of a YOG in action.
A trebuchet is kind of catapult that uses a counterweight to supply the energy for throwing a projectile. It was used during the Medieval Times to destroy castles
When transferring the variables of the YOG to a trebuchet. One may calculate it in the reverse order of a trebuchet.
1.   Value of the drive magnetic on top of the lever = the projectile mass.
2.   Value of the repulsive magnetic ramp array = the projectile acceleration.
3.   Value of the pendulum counterweight = the counterweight for throwing projectile.
Once the value for the pendulum counterweight is achieved. You can convert that to figure to the amount of RPM and torque needed to turn a turbine.
The circumference in the lower part of the YOG plays an important role too. That circumference allows for physical transfer to the turbine or dyno.
For example the YOG, produces about 150 RPM with a 15lbs weight in a one swing.
Find a low drag turbine and look at its rating or chart to see what amount of electricity it will produce.
While your looking for a turbine’s chart, find a low power servo that will orientate the drive magnet and find a low power micro controller that will tell the servo when to turn. Your local hobby store should carry them.
You will see the difference in the input and output.  Free Energy through YOG.  ;)
Here’s a link that has trebuchet formulas.
http://www.algobeautytreb.com/trebmath35.pdf
I hope this analogy helps the readers understand better.
Howard
Howard,
I am not going to debate the merits of your design with you myself.  I think that you are going to have to prove it for youself.  I looked at the clips you pointed to.  In the Bedini clip you can clearly see the person pushing the car back up the track and "compressing" the invisible spring.  Poor old Bedini backed Mylow when there was zero evidence to do that.
You appear to be a long ways away from measuring energy in vs. energy out but that's the only thing that counts.  It does not look easy to do for your setup either.
I will just repeat my suggestion from before:  Give yourself one more year to produce tangible results and if you have nothing after one year then drop the project and move on.
It is crystal clear to me that what you are doing is without merit, you are chasing after a pipe dream.  I know that you will disagree hence my suggestion for the one-year time limit.
onthecuttingedge2005
Hi WattBuilder.
I have placed some questions about your YOG in the pic. please give a description of what they are and what they are supposed to do.
I simulated your YOG on Working Model 2D software but it doesn't seem to work so I need to clear up those questions.
If it doesn't work with Working Model 2D I will attempt to simulate it on Silux 2D.
Generators with moving parts are very inefficient and breakdown and are noisy, it is the generators with no moving parts that are the next step in technological evolution.
Jerry :)
