Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
Cloxxki
Hi Howard,
As you're finding out, it's not so easy to have those who've been disappointed in the past declare OU from a video. A convincing video of a car would be pretty hard to do, had the thing not been invented yet. I hope this will not discourage you.
My concern, from the video would be that the work put into the lever to break through the sticky point, is rather large for the amount of balance in the system. Like a long soft spring.
If I understand the Yu effect correctly, this fixed amount of negative work will be decimized by initial inertia and mass in the system, while the array would be better able to speed up the lever when already in motion, past its entry velocity into the sticky spot? This makes me wonder why H. Johnson never seemed able to exhibit the Yu effect, at least replicably. A second identical gate for this train, and it would have shot through that at increased exit speed?
With the amount of gain you seem to be getting from the array, it seems to me that persuing the tail fin to have a self-runner would be relatively easy for huge amounts of convincing proof. If the gain can't flip a fin 180degrees in it's spot, it'll hard to measure it amount on such a large aparatus anyway. I realize the self-centering will need to be pretty good, but you managed it would the remore controlled servo just fine. A slight damper on the bearing might do the trick. Oherwise, a guide rail.
Looking forward to your next move,
J
FreeEnergy
Quote from: WattBuilder on January 20, 2010, 05:41:07 PM
To ALL Moderators,
Shouldn’t this video be great news and the topic be posted on the forum’s homepage news list ?
Here are the grounds to post it.
1.   I have achieved Overunity.
2.   I have proved The Yu Oscillating Generator can harness energy from magnets.
3.   All Inventors and researchers working towards energy from magnets now have more merit and they are not all crazy.
4.   I am the first to “Publicly prove energy gain from magnets”. Simply because there is no data available measuring In vs. Out with a meter publicly. (No hands)
5.   Most importantly !  Lives can be saved.
Posting this as news would advance further peer review.
My claim still stands on it’s own.
This Video is conclusive proof I have achieved OU.
Video: The Yu Effect â€" proof of energy gain from magnets
http://www.youtube.com/watch?v=iBtl0OTSccs
Howard
do you plan on sending Stefan your invention? or maybe a replica?
or you can just send it to me :-)
Quote from: WattBuilder on January 20, 2010, 07:16:05 PM
Mr Bojangles,
It looks like you did not bother to read my post to you. The lever weighs 0.1 Pounds for the experiment. Think it over again. You will find that when you drop something that weighs 0.1 pounds from 8 feet 3 inches “ which is the height from the middle of my array to the floor”.
You won’t even get close to 1.3 pounds by far.
It’s common sense right ?    ???
My claim still stands on it’s own merit.
Howard
Hi Howard, it is no valid measurement.
You must measure the integral of the force over the distance:
Energy= Integral F ds
Where:
F=Force
s=distance
d= delta
If you only measure peak F values you don´t do it right.
Better try to wire a few coils around your magnets and use
their output to change the direction f the rotor magnet
and thus show a selfrunner.
Regards, Stefan.
el-tigre
Hi Howard,
I had a thought that may help you.  If you build a tail fin reverser, and use your remote control gear to operate a simple solenoid latch which will lock it in place after it flips over, then no one can argue your servo is putting more energy into the system.
Just open the latch when the pendulum reverses and close it before it reaches your magnet array.  This will keep your drive manget from twisting and will demonstrate that the servo can't put any energy into the system.  I was thinking of designing a mechanical latch for this set up, maybe actuated by a small pendulum or a trip lever.
Keep on experimenting and remember, the theories all have to be revised when the experiments prove them wrong. Earnshaw is a great example, and it wasn't so many years ago that the earth was flat and the center of the universe. ;D
WattBuilder
@ Cloxxki,
Correct, The Yu Effect eliminates the sticky spot problem.
As for Howard Johnson who I have the highest respect for. I can’t figure out why he did not measure the output force and show it publicly.
I hope the picture and drawing below helps you out with your concerns. In the picture you will see the lever resting at the start of the field because of the north facing north.
In the drawing you will see the input and output ranges. It’s a big difference.
Note: for the new readers  - the term Sticky Spot refers to the resistance spot.
@ FreeEnergy,
The YOG is too large to ship but Stefan should have plenty of magnets lying around his shop to test the array.
@ Stefan,
My measurements are legitimate and are sufficient to prove OU.
I believe your point of view is looking at the entire energy capabilities of the array. It’s not required to prove OU.
In my drawing you will see I measured the force at point “F” which is more than enough to just prove OU. You can pick a point anywhere from “C” to the floor “I” and it will still show gain.
If you review the picture and drawing you can clearly see the length and force from “A” to “B” is less than the length and force from “B” to “I”
You can also see the acceleration as clear as day.
Respectfully Stefan, I achieved OU conclusive from magnets and it should be allowed to be posted as news for advancement of further peer review.
@ el-tigre,
Thank you for suggestions. I think at this point for me is to get right down to it. Because no matter what I build, the array will be the final key.
Although I must admit judging by the history of other claims. It seems that If I put on a dog and pony show I will get more recognition for my work or hold back secrets and allow for mystery. In the future, the world will look back during these times and we will be judged. Hopefully it wont be so severe.
Howard
