Steven Marks secret
Started by otto, October 07, 2009, 12:26:21 AM
MasterPlaster
I think this post only blongs in this thread.
It is the last thing I received from Otto:
http://www.overunity.com/index.php?action=downloads;sa=view;down=457
Qwert
I posted this material a while ago:
http://www.overunity.com/index.php?topic=2535.msg260660#msg260660
It'd be good to have a reference where everyone could find material alredy posted in this forum in the past.
masster
I was wondering why would you people try to replicate a project of a gay conman that has no clue about science, and even more important, why are you so obsessed with a device that is known to overheat after 20 minutes ?
Bruce_TPU
Quote from: masster on April 23, 2011, 04:09:45 PM
He is not a con man.  It lasted much longer than 20 minutes.  The over heating problem has been solved, and I know how.  The science is real.
Have a good day,
Bruce
equityboost
Quote from: Bruce_TPU on April 23, 2011, 04:39:04 PM
Have a good day,
Bruce
So many threads, it's hard to follow the progression. This thread just dies. Do you have a thread on your successful TPU Bruce?
Thank you.
