Best Motor Design
Started by The Doctor, October 07, 2009, 02:58:44 PM
The Doctor
First post WooT... Anyways down to business.. for the past week I've been viewing youtube and this forum for idea's and possibilities to create a magnet motor/generator.  My question for you would be what is the best design out right now, or in use with particle gains?  From what i can see some motor's will output more then they put in.. although i haven't seen anyone posting there amp's in and out just voltage that designs looks promising... On a second note there is also the    Perendev magnetic motor which also looks promising as its just magnets moving closer to spin a shaft.  I'm wanting to create a generator for my home, i would like to go completely off grid, im using solar right but with only 30% decrease in my bill im hoping someone out there has an idea what would be best for the output..
jonifer
No working magnetic engines on youtube at all, but some interesting construction is in patents office (require further work)
jadaro2600
I remember once seeing someone demonstrate a modified boat propeller which had a large central rotor around which several electromagnetic coils were arranged.
The design was such that the central mass of the rotor was spinning inside a magnetic field, and the commutator was arranged so that current flowing from the central rotor created a current flow when spinning while the electromagnetic coils collected the additional current generated and arranged the secondary magnetic field to oppose that of an outside electromagnetic field.  The effect was a motor of increased efficiency.  Here is a crude drawing...
For more information, you should do your own research on this type of design; it's a well known fact that current builds up in the armature / rotor as the motor spins, no reason not to utilize this effect.
Comments welcome
c1-c3 are connected via the outer rim of r1, note that the link between c1-c3 may be diode protected, and thus there would be no need for c5.  Also, the polarity may need to be reversed in order to fulfill the homopolar action requirements this design utilizes.
