YeahRight's 1capacitor OU or NOU test
Started by WilbyInebriated, October 14, 2009, 01:12:00 PM
WilbyInebriated
yeahright has proposed that by simply using one (1) capacitor hooked to both the 'input' and 'output' coil of a bedini ssg we can determine if it's OU or not!
i am all for this.
as i am not quite sure as to which is the 'input coil' and which is the 'output coil', as soon as yeahright posts a schematic of the proper connections for his test circuit and the required capacitor specs, i will run the test on my ssg.
WilbyInebriated
24 hours later and still no specs from yeahright. imagine that.
i'm sure he is too busy trolling to take the time to have his definitive test actually tested... ::)
WilbyInebriated
Quote from: CTG Labs on October 15, 2009, 02:25:18 PM
John Bedini has repeatedly stated that there is no excess energy in his motors, you can measure them all you like and they will always be underunity.
The so called magic happens in the battery when it is hit with fast HV spikes causing the ions to move themselves in the opposite direction without having to put any current in.
Whether this can be true or not, he has already said there is nothing special in his motors, they are mechanical oscillators design to trick the battery in to performing this feat.
The measurement can only be, when you now run a load from the charged battery and compare to what you used to charge it, etc.  But the very definition of his "negative resistance creation in lead acid batteries" the effect cannot be seen in capacitors.  It relies souly on HV spikes causing attraction of ions which are much slower than the electrons in the outer circuit and this is used to his advantage (supposedly).
Dave.
what has that got to do with yeahright's one capacitor test?
do you have the wiring connections for the cap? or the cap specs? can you tell me which coil is the 'input' and which is the 'output' as described by yeahright? no, so shut up.
yeahright has stated what he believes to be a conclusive test. i'm requesting wiring and component specifics from the little troll. let him put his money where his mouth is, and quit trying to drag this thread off topic.
teslaalset
So why use mechanics to create High Voltage spikes?
This can be done by simple electronic oscillators.
