Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
Mk1
@wattsup
That is essentially what the jt is about , but without the fancy 555 and pwm.
But i have a question , if you can make a tank from one coil and one cap then why could we not make one from two coils ?
Also , it seems no one quite agree that it is possible to get more out then in , most forget the basic thing earth
http://micro.magnet.fsu.edu/electromag/java/faraday/index.html
The compass shows us there is something even stronger then the battery already there and real strong , we can only disturb it when connecting and disconnecting the battery , at the disconnection the field re stabilize , same when pulsing a magnet .
The power is there already we have sometimes have wrong mind set , we do it in the opposite way.
Mark
wattsup
Quote from: Mk1 on March 24, 2010, 12:29:59 AM
@wattsup
Sure you can have how many you want in a circuit. Put 10 different coils in series or some also in parallel and you will be able to eventually find that one frequency that will bring them all to their best resonance. But you still have to live with the off pulse. That is where we lose the game in a solo system.
Even if you had 10 systems in parallel working all at the same time, they all will still share the same off pulse time. But if one is on while the other is off, there is never an off pulse on the output. Nothing is more important then what the output sees. After all, what do we measure the most.
Mk1
I agree the best would be to have two thank in a pull push type action , what if the 2 coil shared a single closed core like Leedslaknin.
He showed us that he could store a charge in a u shape electromagnet for ever , until needed .I am supposed to think the coil don't resonate between each other to keep the momentum , or simply the contained field stores the charge like a regular capacitor ?
I don't mean to be arrogant , i just don't know .
Mark
giantkiller
After reading the Scott Mckie thread I took notice to the twin tank configuration and added my own twist using an h bridge motor driver.
In this configuration the off pulse produces alot less waste. It also uses the 2 caps in the SM17 tpu.
In the Bucking toroid the off pulse actually flips the bloch wall in Zero Space and the rotation of the magnetic flux line direction around the wires.
In the parallel coil idea, as first coil collapses the second generating coil pushes out onto the collapse of the first coil. These are not bifilar but twin tanks ringing and dinging each other. Back and forth. Like the Hendershot.
http://www.overunity.com/index.php?topic=8227.msg233370#msg233370
I have 4 of Jason's SSR boards so I can set the Hbridge up. This is on the list. I have the iron core bucking toroid built. Just finishing off the ends for mounting.
giantkiller
Iron core, bucking pair, 325 turns ea., 265.1865uh.
This one needs to be shielded when run.
When pulsed at ~6.8 another pulse shows up in the off time of the pulse. When run at 51hz there is a large ringing happening. When run at 60hz it crashes the controller application. I believe the 51hz matches up with the grid 60hz at random points. The 60hz matches up all the time.
http://www.youtube.com/watch?v=gD77Wf3QcBs
