Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
wattsup
@all
Here is my last (most probably) video in the series Pulsing coils and lighting LEDS.
http://www.youtube.com/watch?v=P5zXe_iJzXc
I have noticed more and more that guys are using pick up coils with an led to see the energy moving around their devices. That is very great because this energy is very difficult to imagine using a scope and probe, and in many instances, the fact that the probe is applied changes the effect. Just use an led/coil near your device, light up the LED and then try to put a scope probe on it and see what happens.
There are many more effects I have found while doing these tests but in general, what I have shown is the basis.
wattsup
@Hi all
First of all @GK, I am sorry for not responding to your post and to your last build. I kind of had my head in one direction these days.
OK, here is my Video No. 7. I had to cut it up cause the master was too long for YouTube.
http://www.youtube.com/watch?v=2thrf3kq8-E
I think I now know how SMs tpus worked.
Very simple indeed.
First the battery is used but only open ended. Next the pulse frequency is used but only open ended. Then the exchange between that and the Earths field charges an isolated pick up coil that is not open ended. The battery will never go down. The frequency pulse is only on one side, goes through to the other through the battery to the other side. Need more juice, you will need a bigger or more batteries to provide the greater north and south field biases. That's why he raised the LTPU center plate. He had batteries but they did not drain. Or if they did drain, it was taking so long that no battery known could do this, so he won the deal.
He said the 6TPU weighed 1.5 pounds. Hmmmmmm, That much wire would do the 120 volt thing.
It does not really matter what you build. if you use a closed system, you will be stuck to all the conservation of energy laws. But if you go open ended, what law will slam it down. Don't know yet but.............
After the above video, I made connections to a second coil via the free pulse generator ground lead and the free battery positive both going open ended just like the coil that's one the battery negative and pulse positive in the video, again they are open ended, and now............ the second coil is lighting up more LEDS. Amps on the pulse generator did not go up........... WTF man.
I will make a Video 8 but with Video 7, guys should understand the implications of this easily. I can only hope.
Monopoles do exist. You have two of them on each battery, inductor, capacitor, etc. We are the ones that are so bent on shorting them to get some work done.
Plus we have one major field whooshing around our buts day in and day out.
I think now that SMs vacuum tube analogy was to depict an open ended system. There is a space between the anode and the cathode. A vacuum tube is in fact a concentrated pinpointing on an open ended system. Pulse one side, bias the other and juice starts flowing.
Ottos ECD. He used some serious juice to pulse them. Not like my furty Pulse Generator in mA and uA. I think one day he started it and one of the leads was not connected making it open ended. The power supply ground did the same thing on one side as how it is being used it in the video. He hit the frequency from the other side and bingo, Bright's your Uncle. lol
Remember the small coils I wound on the coil ends shown at 2 minutes in Video6? Ottos' CC's did the same thing but even more concentrated, pin point like in three vectors. Man oh Man. I will have to dust off my ECD build..
I will have to make a diagram to explain it but in general.
Use a pair of wires to wind a first coil.
Battery negative on one wire.
Pulse positive on the other wire.
Use a pair of wires to wind a second coil.
Battery positive on one wire.
Pulse negative on the other wire.
Or, regardless of what you build, find the coupling wires and do the same thing. Put one on one and the other on the other. Pulse around and have fun.
otto
Hello all,
@wattsup
nice videos!!
Your idea is something like to split a TPU into a positive and a negative pulsating "system"?? Top "half" of the TPU would be positive and the bottom negative pulsed??
Can you post a schematic for us so we can easier understand what you did in the last video?
Otto
Otto
forest
wattsup,
I'm quite tired and not really understand what you explaining but I had surprising effect just with flyback or car ignition coil with attached extra coil.Is that what you are  about ?
tsl
hello all
@wattsup
nice idea.actually the open system is not so open couse the conductor pairs are actually amounting to a condenser so you get a nice hidden tank circuit( you have the coil and the "hidden" capacitor).it seems that you're still going to get to the transmission line theory in the end.i had also proposed allmost the same to some members over pm.keep up the good work :)
cheers,
tsl
