Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
0 Members and 47 Guests are viewing this topic.
h2ocommuter
I looked around and waited till I found the illuma storm because it has the two pots integrated into the circuit. I felt it would allready give me adjustments I could not achieve on my own.
With 14 turns with jumbo speaker wire, on my L-2 it can be adjusted into resonance. Well to me that is the highest oscillation value Hz.  What ever I am not too sure. The adjustment sensitivity gets highly magnified when its getting close to the maximum output zone.
What is curious is the stimulation seems to be the absolute calmness that can be achieved. "visually".
I have a good copy of a freq chart but it is too big to send with a post if you want a copy.  I does not match up exactly to the tables and formula nomograph but it is really close. I use it in my pdf and my excel charts.
bw
H2o, I'm emailing  the address you mentioned to "pound the counter" a little too.  Even if we find all five I think they may just be updated versions of one book, I'm not sure.   Someone does seem to be releasing more information on Don's work, a little bit each time.
I'm very interested in your plasma globe results, it's the first thing of Don's I tried to make work.  I've learned more now and want to try it again.  My old globe burned out and Radio Shack says they don't carry them any more.  Did you find yours there?  100 amps, that's just bad to the bone.
giantkiller
On my Smith ring the 7 turn feedback winding has natural resonance at 188k like the others. But because of the different inductance the tank cap will be different.
Iron is bad. The resonant freq is all the same for the different windings of 7, 12, 36.
So now I am going to wind the same thing on a styrofoam ring.
Somebody sent this to me. Ed is charging up an iron rod. I never saw this before.
wattsup
giantkiller
Yep. Bizmuth plates.
Didn't spend too much time on it because of the special materials.
But there is resonance in that device also.
Quote from: wattsup on December 15, 2009, 10:40:09 PM
@GK
Have you seen this?
http://www.youtube.com/watch?v=ZUvHhBzffWk&feature=channel
