Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
0 Members and 79 Guests are viewing this topic.
forest
photoelectric effect of longitudinal wave,if you wish to find a proof it is in one of Tesla GB patent
sparks
   Would a sound wave travelling through a plasma be called a scaler wave.  Tesla was into making plasma because he understood it's conductive properties.  What if he was gonna create a plasma from tower top to tower top and then transmit waves through the plasma.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
bw
  "You will have to use energy from the cap to saturate the core of an inductor but you will not have to use much to collapse it.  The collapse mother nature does for you and quite rapidly."
[/quote]
Sparks,  this might be a dummy question but is this what that means?   When a load(work) is connected and demanding a lot from the inductor then the collapse or spark to earth would occur less because the load is using what normally would seek another path to earth ground?  If the load is reduced or removed I guess the cap would discharge much faster, mother nature.     Would that be what this means?
Another dummy question is bugging me.  If the wire on the receiving L-2 coil is 1/4 the length of the L-1 coil would the nst frequency being fed into L-1 be four times greater in the L-2 coil?  I know turns adjust volts but length?
Also, your explanation of the other stuff is very helpful to me.  Thanks
bw
sparks
    BW
   Once we have the capacitor charged by whatever power supply whether it be a radio signal capture into a resonant circuit or a photelectric cell or perhaps an aa battery the next step is to store up this energy in a magnetic field.  Like we would find inside the core of an inductor.  When the capacitor is discharged to the inductor the inductor is like a flywheel.  At first no current will flow.  What is happening is that the coil is changing the magnetic field within its turn.  This is causing the coil to also generate voltage back against the capacitor.  The space or core of the inductor is going to saturate at some point and then the capacitor will discharge very rapidly with only the resistance of the inductor which is low now in play.  If we interupt the circuit before the core saturates the ambient magnetic field will return the magnetic field within the inductor to whatever it was before things got changed.  The core will magnetically reconnect with the ambient magnetic field Don was talking about.  This will produce a changing magnetic field within the core of the inductor that is fast unless we have steel or other ferromagnetic stuff in there.  This causes a large voltage spike which is supplied by the ambient magnetic parameters not by any supplied voltage.  We have to remember that voltage is induced whenever the magnetic field is changed around a conductor.  Doesnt matter if it is going from concentrated to diffused or vice versa it is going to induce an emf.  The faster it changes the higher the emf.
Think Legacy
Spread the Love
bw
