Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
giantkiller
Take the elongated device in the Kunel patent and change the geometry in two ways. Shorten the length and widen the diameter. It now looks like a TPU. Pulse the 20 end coils in the same direction to create a toroid ball field. Pulse the middle one in reverse to break the bloch wall of the original field. You now have a virtual spark gap or electrostatic charge pump.
http://en.wikipedia.org/wiki/Petra
bw
I think you got it GK.   I assume the 3 standing stones on South wall and 2 on E. wall are spaced or tuned to resonate off a straight wall on the opposite side.
John Hutchison hit the frequency of the atoms inside of whatever metal he wanted to turn to jello.  Cool
wings
Quote from: bw on February 12, 2010, 07:08:37 PM
"This is an acoustic levitation chamber I designed and built in 1987 as a micro-gravity experiment for NASA related subject matter.
The 12 inch cubed plexiglas Helmholtz Resonant Cavity has 3 speakers attached to the cube by aluminium acoustic waveguides.
By applying a continuous resonant(600Hertz) sound wave, and by adjusting the amplitude and phase relationship amongst the 3 speakers; I was able to control levitation and movement in all 3 (x,y,z) axis of the ambient space.
This  was used to show the effects of micro-gravity conditions that exist in the space shuttle environment in orbit, but done here on Earth in a lab.
This is not "anti-gravity." So don't waste time arguing something pointless.
SEE: http://science.howstuffworks.com/acou..."
this using 3 Helmholtz Resonant Cavity has 3 speakers and works under gravity potential
http://www.youtube.com/watch?v=94KzmB2bI7s&feature=fvw
...... TPU use 3 electric voltage oscillator and work under earth voltage potential
...the ball the electrons ..
... under high voltage lines it works better.....
similar effect
http://www.rexresearch.com/plauson/plauson.htm
giantkiller
http://www.denver.net/~paul/   updated
'invisible wall' in adjuncts
corrupted vid in 5th step fixed
iron rod vid in generator room
These links tie even more together.
even more on the way...
phoneboy
@ GK, be careful with your Trinity device you may be inadvertently generating infrasonic sound which can kill @ the right freq/power levels
