Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
sparks
@ GK
   If your circuit is able to make transitions which are quite brief and then a second phase displaced transition that mix in the same circuit then your emp energy starts to get into the xray and above regime.  This is where atoms start spitting electrons.  If the atoms are moving already the electrons they spit will be too.  The electrons will react to an electric or magnetic field whereas the neutral atoms in molecular bonds won't.  Bang em bang em real good.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
This says to me 'Double pulse protocol on an air coil in a ring'. I have my controller up and running and have been testing with it. I ordered the next dual channel DDS controller coming from Jason. The frequency spec is tighter and we are going to ramp this up a notch with new software also. The sport model is the next build I have in line to test. It is not wired in bucking fashion tho.
Quote from: sparks on March 26, 2010, 10:44:04 PM
@ GK
giantkiller
Look at the 'magnetically quenched spark gap' as an 'electromagnetically quenched bloch wall'. Between each discharge the Bloch wall reasserts itself snapping expediantly back across the 2 conductors of the terminals. The charge side goes to the source capacitor. The discharge side goes to the load side capacitor. The speed at which it returns makes the conductor look like an inductor.
Then as the power wave deccelerates is conducts through the load side of the circuit filling up the capacitor. But before the slow decceleration the capacitor has already taken on a charge from the high speed potential.
giantkiller
Pentagon Aliens, Pages 27 - 33
Model T (A.K.A. Flivver(Tesla hidden right under our noses)) ignition coil fired by a spark gap is federally illegal. Guess I broke the law, big time.
3 years ago I stated the  SM17 was a stungun.
2.5 years ago I showed stun guns in a circle firing into the next one to make a loop. I fired a stun gun into the GK4 to see the dartlets.
2.5 years ago I stated connecting a stun gun to a 15 foot, large loop of audio cable. Was told 'No'.
2 years ago I stated Wardenclyffe was the worlds largest stun gun.
Grumpy posted numerous pix from Tesla patents showing more than 2 stages of spark gaps, caps, and inducting coils.
Flip the gag order around and you have blatant instructions:
QuoteNo mass circuitry
means
QuoteMass produced circuitry
SM mentioned
Quote5khz
which equals stun gun which equals Tesla technology.
There are 3 ways to get this process going:
1: Spark gap to inductor stages.
2: Resonance of magnetic or mechanical means
3: Dual pulse protocol.
It is fini...
