Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
0 Members and 40 Guests are viewing this topic.
bolt
Quote from: NickZ on August 09, 2010, 01:28:08 PM
  Bolt says that to try using magamps in a system would take forever, but won't even take the time make one himself, as proof of concept.
                                         NZ
It takes money and a FULL lab. Only a few people here have that facility.  The magamp takes place of the fet thats all it does. Just an amplifier or switch. When you have a working TPU then the fet can be replaced with a magamp. Its cheaper and and infinitely more robust. If you want to play with mag amps then google search for simple DIY experiments there is a youtube vid for a light dimmer and xtal radio driving a speaker using tiny transformers as amplifiers. There you will learn what the 5Khz clock is for.
giantkiller
Just a start from my pile.
Need a bigger NST and neon isn't on.
4 ratshacks in series to up the turn count. 88ohms.
Got to pull some more goodies from my 'way too much' pile.
Its important to have too much stuff.
Bigger NST(thanks Bruce_tpu), 38khz, 6kvac, purple fanning in Neon. I dare not put scope directly on this.
The game is afoot. I gotta crash. Back at tomorrow night.
I don't remember the neon producing purple before. Hmmm, something new.
Camera can not pick it up or focus. Ain't normal light.
Anybody else building this? Or just lurkers?
This setup looks like Tesla coil with a high impedance primary, no secondary(yet), and no top.
e2matrix
somehow got a double post - corrected one next...
e2matrix
Very interesting video here by Dr. Eue Jin Jeong.  Mosty text and equations but I believe some of his concepts are very relevant to the TPU.  He even mentions 5Khz and in his final equation he mentions the 5Khz and 5000 watts of power.  Take a look before it's gone.  I see Youtube is making it more difficult to download and save vid's.  Youtube:
http://www.youtube.com/watch?v=NhXV3ca1J6g
I see he has a more recent vid that has lowered the power output to 2500 watts.  Theoretical but still some very impressive thoughts in this video.
Dr. Jeong's blog site: www.dipoleantigravity.blogspot.com
sigma16
Quote from: NickZ on August 09, 2010, 02:31:09 PM
  @ Sigma:
      I understand where you're coming from.  We are all in the same boat. But, if the idea is to help in this effort, please explain about the effect generation process that we are not looking at.
As I have already said:
1. Wind up a simple solenoid coil with about 2000 to 3000 feet of HT magnet wire.  something around 28 AWG diameter, but doesn't really matter for this test.
2. Get a HV DC power supply.  Small neon power supplies like those for neon lights on cars are good with 2kv as a minimum.  4kv works good.  8kv is better.  10kv is even better.  Use some HV caps across the output to help keep it steady, say .01 uF of more.
3. put some sort of spark gap on the positive lead to the coil, other is grounded to pulse power supply
4. put a very small cap across the supply right before the spark gap
5. pulse the coil and you will find that within the space around it, conductive objects are attracted to the coil
Now, what you make if it and what you do with it, is up to you.  Tesla kicked this ball down the field toward the goal.  Most people just stay in their self-imposed coma.
What is it?  Tesla called it "radiant force".  The term "radiant electricity" was used for the charging of objects by this "radiant force".
What's really going on?  You are compressing and expanding "space", the "medium", the "ether", the Vacuum, The Dirac Sea", whatever you want to call it.  Lot more to it than that, but that is all you need to get started.  How this is occuring is anyone's guess.  I have my own ideas that I plan on keeping to myself for now.
Steven used a lot less wire and a different method, same end result though.  This is just a force and not converted to conduction current so don't expect too much. I expect that the 5kHz hash Steven saw is related to his method of producing this force, which I believe is not continuous in his coils.  Perhaps he will read this and comment.
