giantkiller
The two tuned coils created greater impedance through harmonic resonance? Wow that was a Deja Vu moment.
http://www.alcorn-energy.com/tech4.htm
QuoteWhenever power factor correction is applied to a distribution network, bringing together capacitance and inductance, there will always be a frequency at which the capacitors are in parallel resonance with the supply.
If this condition occurs at, or close to, one of the harmonics generated by any solid state control equipment, then large harmonic currents can circulate between the supply network and the capacitor equipment, limited only by the damping resistance in the circuit. Such currents will add to the harmonic voltage disturbance in the network causing an increased voltage distortion.
This results in an unacceptably high voltage across the capacitor dielectric coupled with an excessive current through all the capacitor ancillary components. The most common order of harmonics are 5th, 7th, 11th and 13th but resonance can occur at any frequency.
AVOIDING RESONANCE
There are a number of ways to avoid resonance when installing capacitors. On larger systems it may be possible to re-position the proposed capacitor installation onto another part of the system.
The same value of kvar installed at high voltage rather than at low voltage may eliminate a resonant difficulty, or there may be other low voltage busbars where there is no harmonic generating load. Varying the output rating of the capacitor bank will alter the resonant frequency.
With multi stage capacitor switching there will be a different resonant frequency for each stage. Changing the number of switching stages may avoid resonance at each stage of switching.
OVERCOMING RESONANCE
If resonance cannot be avoided an alternative solution is required.
A reactor must be connected in series with each capacitor switching section such that the capacitor/reactor combination is inductive at the dangerous frequencies but capacitive at fundamental frequency. To achieve this the capacitor and series connected reactor must have a tuning frequency below the lowest order of harmonic to be experienced, which is usually the 5th.
This means the tuning frequency is usually in the range of 175Hz to 230Hz, althouth the actual frequency will depend upon the magnitude of the harmonic currents present. The actual tuning frequency will be varied to suit the specific needs of each case.
The inclusion of a reactor in the capacitor circuit increases the fundamental voltage across the capacitor in the order of 5 to 9% in addition to the harmonic voltages previously mentioned.
There is a whole science of Nethanderalism! Friggin' stupified.
Well, well, well! I knew I had seen this in this view before. Same as Tidal waves! Can you believe these idiots want to squash overunity by grounding or hampering resonance!
This thread so aptly named...
Simply the interaction of 2 coils in resonance. Don even said 'The circuit blocks talk with each other'.  He also talked about 3rds, fifths, and sevenths. I just found his divisors are compliments 3, 5, and 7s.
With a core height of 2 inches the primary turns are 5" in length. The secondary is 6" in turn length. The snake biting it's tail.
Some days I wake up better than other days.
Yep BW, you're right again. Have a beer. I am.
bw
Remember the folks working so hard to conceal overunity count their profits in billions per hour right now and
will do ANYTHING to keep it that way.  This is why open source is so very important.  When the secrets are
all out things will change.  The energy folks who control governments will find themselves holding many
barrels of hazardous waste material.  Folks won't have to work half their time to buy fuel.  A lot of jobs
will evaporate but if we have no energy expenses we won't need to work so much anyway.  Just get a
fattie and chill with the extra time.
  Dangerous stuff.
Very powerful buttheads running that show.  Just follow the money trail.  The Big Butthead J.P.Morgan told Tesla his wireless was better but he couldn't put a "meter on it".   We've been slaves to those asses too long.
MACEDONIA CD
helo  <<bw> i see plasma  butt  what is the resolts  i thing is only sparking how you whill coneckt the load  <real>  if make like  don smith
you know  whell that is no real IST traid this put load and nothing
no real load can be  working there <that is the problem ???
THANKS
giantkiller
innovation_station
Quote from: giantkiller on December 02, 2009, 06:26:19 PM
You fast charge caps and slow draw off.
sounds like a REALLY  safe way to do it from a tiny source ... and simple i might add
ist
