We are entering the competition officially
Started by ltseung888, October 30, 2009, 10:32:04 AM
tagor
Quote from: ltseung888 on November 05, 2009, 01:55:09 PM
  I do not mind working out a deal so that you can improve and distribute the product in Germany.
If Stephan gets a working device
I can distribute it in France
hartiberlin
Dear Stefan,
Our feedback can be even better than that.  Our Drive Coils are very effective Collector Coils during the no current period.  That energy is sufficient to recharge the batteries.  (Similar to the Bedini type set up.)
The size and weight will be reduced by our partner factories.  We intend to send you the factory version with much better machining.  You are likely to receive one from the first batch rolling out from the factory.
Since you are better qualified than most, we shall tune your device to generate not just 2 or 3 watts.  It will be more like 50-60 watts.  You can set up extremely convincing demos at your site.  I do not mind working out a deal so that you can improve and distribute the product in Germany.  You may even represent us in one of the Inventor Shows in Germany.
We hall have fun and benefit the World  together.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
Hi Lawrence,
many thanks for the infos.
Looking forward to see, what you have.
Please keep me posted also by email.
Many thanks in advance.
Regards, Stefan.
IceStorm
Since you use inductor , the current phase angle relative to voltage cant be in phase so i think its realy important to show a scope shot of this 2 because showing a voltmeter and a amp meter dosent tell anything if they are not in phase.
Best Regards,
IceStorm
ltseung888
Quote from: IceStorm on November 06, 2009, 11:25:48 PM
Best Regards,
IceStorm
We have onverted everything into DC for comparison.
ltseung888
Continue the Experiments on the 60 cm wheel
Now that the Inno Carnival 09 Open Show is over, we can continue working on the 60 cm wheel.
The following will be done as shown in the diagram.
1.   The Proximity Switch (PS) will have its own 12V battery.  It uses a small amount of current.  The chance of it blowing up is small.  We can replace and then recharge the battery by the Wheel from time to time.
2.   The feedback circuit.  We have to be very careful on this one.  In the diagram, the drive coils were not shown for clarity.  Once we closed the switch, DC current will pass through the Relay depending on the action of the PS.  Our Relay was rated at 40 Amps.  Two were blown up.  This implied that we might have current exceeding 40 Amps at certain times.
3.   At one time, we fed back the entire Lead-Out Energy Output after converted to DC back to the battery as shown.  The DC Voltmeter exceeded 1000V which is the maximum on our meter.  This and step 2 confirmed that we indeed had the 2, 4, 8, 16, 32 multiplication effect.
4.   Blowing up electronics and melting wires were to be expected.  We now need to add current limiting circuits, change to thicker wires, replace diode bridge to take on the much higher current, etc.
5.   The chance of our producing Output much higher than the 3 watts in the Inno Carnival 09 is 100%.  From our data so far, if we can control the feedback voltage and current, we should be able to produce a 5KW electricity generator with our 60 cm wheel machine.
6.   However, we shall build another new prototype with better material â€" wood is too dangerous as a fire hazard.  With Divine Help again, the machine will be ready for the December 3 Show at the Hong Kong Convention Center.
7.   Beijing is asking for the 5KW electricity generator.  The evaluator said that: “Senior Officials cannot read nor trust meters.  But they will understand turning on many light bulbs, heaters or air conditioners.”
We have conclusively demonstrated overunity at Inno Carnival 09.  That is sufficient to win the Prize.  Now we need to demonstrate a 5KW electricity generator for Beijing, the White House and United Nations, we may send a similar one to Stefan too.  He can show his visitors that he never needs to pay electricity bills again (may even supply power to the grid and earn a decent sum for his years of effort.)
