Debating Voltage Potential Videos 1-3
Started by Brian Coats, October 31, 2009, 10:41:26 PM
Brian Coats
Here are some videos I made for "Share" to those that are interested in them. The Videos show a fluorescent lamp in parallel with 9 tubes. The tubes are also parallel with each other and the fuel cell contains only tap water.
I Currently do not have the time for testing, and I'm not sure when I'll be able to play again. However I leave these videos to whoever is interested in them. I used 9 tubes in parallel because I didn't really have 1 single tube available. All my wfc stuff has been stored away. The gas production on 9 tubes is small but visible, where using just 1 tube would have been very visible on video. These videos was released because of a post I made on the forum I created if interested, They are on the other forum under my project section.
I explained there how I only shown voltage potential across a cell, I did not explain how to make the voltage resonate with the water molecule, Nor does the videos show resonance between voltage potential or the water molecule.
Those thats interested in gaining this potential across any given cell containing only tap water, these videos are for you to retrofit into your resonance test time. Also note, The voltage is present when there is no current flow, And, the current flow is only present when there is no high voltage. Voltage and current is out of phase with each other, they never meet which is why kilovolts can be read across the conductive cell.
Negative as well as positive comments are very welcome Both here, and on youtube.
Have an Great testing Project day!
Brian Coats..
http://www.youtube.com/watch?v=4wOdfP6EY8Q
http://www.youtube.com/watch?v=lOIoFgn-WaQ
http://www.youtube.com/watch?v=1xueNufRDBw
