Scalar Wave - Energy
Started by mondainmax, November 02, 2009, 04:19:24 PM
xee2
I saw this video on youtube which shows that a metal plate shields coupling between coils. Theoretically this should not happen. I did a test just to check, and the metal did not provide any shielding between the coils in my test.
video:  http://www.youtube.com/watch?v=9hKidYAuWNE&feature=related
darkspeed
Stainless??
Stainless is not magnetic - it wont block the magnetic flux between coils
xee2
@ darkspeed
Very true. But metal in video was aluminum. That is why it seemed strange to me.
xee2
@ Loner
Thanks for the update.
I am not a welder either and I do not have an arc welder. So my experience is almost zero at welding. But the heat generated in a resistor is equal to the current squared times the resistance. Thus I would not expect a wire with almost no resistance to generate much heat. I think a spark has more resistance than a wire so by the same equation the spark would generate more heat at the same current. But, I do not think the spark obeys ohm's law, so the equation may not apply to sparks. But a spark is hot enough to light paper on fire where as the wire does not get that hot. Thus the spark is deffinitely hotter than a wire carrying the same current.
xee2
@ Loner
The CB antenna will not transmit out of a Faraday cage, so I think it is just a matter of how much shielding there is from the foil.
