Flynn's Parallel Path
Started by longwolf, March 10, 2006, 04:07:45 PM
jake
QuoteIt seems to me all that is going on here is just adding up the electromagnets and permanent magnets and focusing them all in one direction.
That is exactly what is going on.  And that is all that is going on.
I just took a square core and wound a coil on one side and a coil on the other side.  I am putting 5 volts in on the input coil and getting 100 volts out on the other coil!  2000%!  I'm going to hurry up and patent this thing because I've seen it work.  It really is working!  I'm getting out 95 more volts than I'm putting in.  I will post instructions if anyone wants to replicate what I'm doing.
gn0stik
Quote from: jake on May 30, 2006, 04:05:54 PM
Uhh, I think I smell sarcasm, but I'm not sure. Is this for real? If this is not sarcasm, of course we'd like to see and/or replicate what you are doing. Of course, just a voltage increase means nothing in and of itself. Could be you just reinvented the transformer.
jake
Good nose.
Now, can you explain to me why this doesn't work?  I can assure you that I can wind a transformer to give me 2000% voltage increase.  Why is this not overunity?
gn0stik
Because you didn't increase amps with it. V(A)=W
jake
But the math doesn't matter.  If I get 100 volts out, I can just hook up a light bulb and I'm getting more out than I put it.
I have 50 turns on the input, and 2000 turns on the output.  When I apply 5 volts I create some flux through the core.  This flux is passing through the other coil and it is picking up 100 volts from the flux.  I'm sure it will work because it should work.  If I hook up a load, the same amount of flux will still be produced by the 5 volts, so I will have the same flux through the output coil, so I will get 100 volts from 5 volts input.  This has to work.
