Hilden-Brand Magnet Motor
Started by JackH, March 10, 2006, 11:58:55 PM
Elvis Oswald
Jack,
I have a question (or two) about your motor (if you don't want to answer, I'll understand.)  :)
How many rotors does your motor have?  How many poles?
And a general question about your experience with this design - the closest field coil must attract the rotor when the permanent magnet is turned off on that pole... do you account for that by adjusting the power to the field coils or is it just not an issue?
hartiberlin
Hi JackH,
how do you measure your efficiency ?
Do you measure the mechanical output via a prony brake
or do you couple to your motor a DC generator and measure DC output versus
DC input power ?
If the latter is true, what kind of DC generator do you use and what is
its efficiency at the used RPM you tested ?
Or the other way asked:
What would you show at a meeting or private demonstration
to prove, that the motors are really overunity ?
Many thanks.
Clarky
He must be talking about co-efficiency of performance, not efficiency.
So to correct that statement if true, his COP is overunity at 250%. His mechanical efficiency (friction, heat, air resistance) will never exceed 100% at best.
Hello Jack Hildenbrand,
if you have got enough time and an electro-magnet,
could you try to amplify the e-magnet force with your concept ?
Sincerely
            de Lanca
p.s.:it is my own interest to remove the P-magnet by an
E-magnet in the static generator,so you would give me a help !
I know about the P-magnet force amplifying kinds like offered
through "NorthWestmagnets" and "AMS/AMT" and the e-magnet energy savings through "Solenoidcity" !
And the static generator use this closed-magnet-cycle concept !
This is only to show that I am not abusing your PERSON or make
your temptations/work ridiculous,
and this is only the beginning of the C.O.P. over 1,
Oskar Becker:with on/off e-magnet work and LEVER-use:C.O.P.100/200/...
E=electro
P=permanent
Sincerely
            de Lanca
p.s.: I please you to be carefull with numbers(it shall be in your own
interest) and as example:
the common heat pump has a C.O.P. of +/- 3(or 300%),
but an efficiency under 100% !!!
And as review:When a worker is holding hours-/days-/months-long
a thing -without vectorial movement,ever on the same XYZ point-he is -physics laws related-doing nothing !!!
You have -physics laws related-not to pay a cent for this "labour"!
The worker would shout you:"Silly,mad stupid,....!" but I only
welcome you (and him) to the  "non-/linear physics" !
It is an OFFICIAL PARADOXON WORLD !!!
