OU prize OFFICIAL ENTRY
Started by gadgetmall, November 21, 2009, 01:00:52 PM
gadgetmall
i produce 9100 watts or 3500 amps @ 2.6 volts from 5 1000ths of a volt from an aa battery charged to 1.495 volts 2500ma . after test and secondary Bcap charged ,volts from the primary aa battery were 1.490 .
The Worlds first Heater discovered and now invented by me in a simple OU demonstration . I claim so and welcome replications .
introducing
The Worlds First AA battery Heater  / Light Source
And you may replicate it to verify My Findings and Invention . Its Build in about 5 -10 minutes and cost less than 100 dollars each . here is MY schematic .
Gadget
poynt99
I would strongly suggest you start your own thread as a take-off of the JT thread, and clearly illustrate the circuit (which I think you have already posted), along with an explanation of the measurements you have made, and what you are claiming.
.99
gadgetmall
Quote from: poynt99 on November 21, 2009, 01:39:13 PM
.99
Thanks you Ponynt99 . there is a full explanation on the jule thief thread from page 997 to page 1003 . and also there is a new thread second stage joule thief  where advanced information can be discussed . i am officially entering the contest and also anyone can replicate this in 5 or 10 minutes . the 2500 amps or 9100watts is a fact and a spec. for the ultracapacitor i am using here are some of the specs.
Short circuit current Is 3500 amps
maximum continuous current is  105 amps
maximum peak current for 1 second is 875 amps
weight is 0.02 kg
power dissipation max is 15,100 watts per kg
emax energy is 3.29 wh/kg
My circuit charges one of these then it is discharged into a load  be it nichrome wire or other devices requiring large amounts of current @ 2.5 to 2.7 volts .And like your slogan . its so simple and right under our nose .
gadget
poynt99
Thank you for clarifying your diagram. It is still a little unconventional, but I think I get the idea ;)
I read through all the pages starting at P.997. There are a number of voltage values, but not much else to go on. I also read the SSJT thread.
Could you please explain what has led you to believe that this circuit is producing OU?
Thanks,
.99
gadgetmall
Quote from: poynt99 on November 21, 2009, 06:15:24 PM
Thanks,
.99
OK what is OU . Its Over UNity . What is Unity in this circuit . Its the AA battery start voltage  and amp. which was 1.495volts @ 2500mah . ok primary source . running a simple STANDARD Joule thief  circuit with a tank on the base . and a secondary of 22 turns for the leds. In this case you really dont have to have the leds . its a plus free energy . i use two .5 watt 5 chip leds . with the circuit adjusted to 13ma with teh ultracap 650farads 2.7 volts connected and discharged to .500 volts or a half a volt . the reason its at .500 volts is this is where transistors stop working and is the normal for my discharged caps . they dont work a Jt any more with a silicon transistor . I turn on the circuit . the Leds are approximately half bright . 14 hours later i have a full ultracapacitor with a causal 2.6 volts . I never charge these caps up to 2.7 volts the highest before they become extremely dangerous and could blow the pop off screw on the side / . Ok . So now we have a 2.6 volts with a maximum capacity of 3500 amps as per specs on the maxwell web site . before i  kill the circuit after looking at the run AA battery voltage it stands at 1.490  or 5/1000ths of a volt dropped and theleds are now 3/4 bright . too bright to stare at .. BUT ALSO i have 2,6 volts Charged in the Bcap At a VERY HIGH AMPERAGE well beyond the  tiny AA battery that burns nichrome wire . Simply Hit the AA battery for 5 seconds and the aa battery is well above its staring voltage . It's like hitting an aa battery with a 100 amp charger . Only for a sec the battery gets hot quick and charges up fast . Now . i still have 2.6  2. 5 volts to light up Nichrome Wire coil and get warm and light up a cigarette. This is way over the Unity of the run battery . See now ?
Gadget
