Ultracaps tested for excess energy
Started by PaulLowrance, November 30, 2009, 12:47:01 PM
gadgetmall
Quote from: PaulLowrance on December 08, 2009, 10:56:30 AM
That's great that you use very common parts that most people have. I have everything you mention. My Ge diode is 1N34A. How would you describe the permeability of your toroid-- ultra high, high, medium, low, or ultra low, etc.?
BTW, anyone who wants a bookmark page of my data logger circuit w/ UC slow charge / fast discharge experiment can go here,
http://globalfreeenergy.info/2009/12/08/ultracapacitor-experiment/
Paul
the toroid specs are unknow but are very common and the conclusion is they are good so i would sayhigh permeability low flux.. What i suspect in this simple circuit ,much like a bedini circuit is the tah out put from the ce junction  contains volts ,amps and High back spikes that this unique  bcap absorb readily and converts that static pulse in energy  unlike a battery that converts it to a static charge (ghost charge)
So simple . The Best Ideas are always simple and right under our noses !Math cant touch it !
Ps . In fact this is a bedini circuit in self oscilation mode . If you were to wind a bifialar coil afouns an iron core you could run a magnet wheel off it for free . A FACT . i have build over 25 Bedini energizers . This is the circuit . trigger will come from the  magnet passing the coil to fire the transistor . RPM can be as high as the transistor oscillates and friction allows  for your mag wheel . Then you can capture EXTRA energy By harnessing is with coils of coper wire without cores in effect  no lenz effect  noticeably .
Albert
PaulLowrance
I also have lots of NiMH AA, AAA, and 9V, batteries.
BTW, I recall your circuit had an LED as well, but your new one does not?
Paul
gadgetmall
Quote from: PaulLowrance on December 08, 2009, 11:12:37 AM
Paul
USE a GOOD NI/MH . and i have LEDS IN ALL OF THEM . I use 1 watt leds off an unfiltered 22 turn Secondary . This is an option but makes a nice perpetual light source and my first design uses it so i stuck with it . I now have BIG 3.1/2 inch high perm toroids that fire CFL bulbs and use tip 3055 . It produced 4 times the voltage but it also draws 4 time the current . I am working on lowering the input  of that one . the Nice thing about the OU controller being make is it will accept any jt  transistor junction as long as its not extremely high output .  . It took me 15 minutes to wind the big torroid  and put that circuit together  to fire off a Fl tube . . its still running since yesterday off one of those aa ni/mh 2500 mah batteries . Energizer from wallmart  > i can wind and solder the one your making in less than 5 minutes without looking at a diagram because i have made hundreds of them . ranging from a tiny ferrite bead that fits on a transistor leg to a 6 inch toroid . The big ones take longer of course as some have ober 300 winds on the secondary .
Albert
PaulLowrance
Quote from: gadgetmall on December 08, 2009, 10:38:45 AM
i use a 68 pf disk cap across the resistor also .
Thanks for the info. That should be enough to build it, except one thing. In your older circuit I have written down 1000pF across the 2K resistor. That's changed to 68pF? The 2K resistor (now 2.2K) is the one that goes directly to the 2N2222 base.
Thanks,
Paul
innovation_station
yes gadget ...  math does ANSWER ALL ...
if the HU-MANS ever find the MATH OF CREATION ...  hummmmmm
369 ringggggggg 9 bells?  lol
ist
