Ultracaps tested for excess energy
Started by PaulLowrance, November 30, 2009, 12:47:01 PM
PaulLowrance
I bumped it to 10.70mA in, and 1N34A went to 5.0mA
PaulLowrance
That's using the DMM in-series with the 1N34A, but maybe it's interfering too much. Give me a few min to connect a 0.1 ohm R and then use the Keithley to measure the voltage across it to see the current.
Paul
PaulLowrance
Using a 0.1ohm resistor in-series with the 1N34A to determine the 1N34A current, instead of the DMM, there's 19.07mA input, and 1.074mV on the 0.1ohm resistor, which comes to 10.74mA through the 1N34A.
PaulLowrance
Quote from: gadgetmall on December 10, 2009, 09:22:09 AM
As far as having a 2000mah battery i am using a 2500mah and have kep one running ver 16 days and recharged the bcap 7 times above unity of teh source . battery remains at 1.300 where i regenerate it with the light bulb regulator .
Wow, that's incredible. Are you saying that your 2500mAh NiMH battery has recharged the bcap0650 from 0 to nearly 2.7 volts seven times without regarging the 2500mAh battery??
Paul
innovation_station
great mesurements paul !
you gotts what it takes ...
i would say it works as designed to ...
gadget see why you were first ..
w
