Thanks to ALL for your help!!
Wicking Works
Started by onthecuttingedge2005, December 02, 2009, 02:53:53 AM
shruggedatlas
Quote from: onthecuttingedge2005 on December 02, 2009, 07:26:25 PM
Something like this.
But water always seeks its own level.  Why would it stay in compartment B rather than emptying into the lower container?
Quote from: shruggedatlas on December 02, 2009, 10:12:40 PM
A. and B. are sealed, this creates a higher vacuum up top than the lower water in B., the vacuum at the top chamber B. will cause the water to be drawn up from device E. which is only allowed to flow one way.
should be pretty easy to verify, I will see about finding a one way valve somewhere.
FreeEnergy
what if you have capillary tubes and you place a wick at the top so it drips back down?
what if you have 4 wicks in each tube starting from the smallest to the biggest, each wick helps transport the liquid to the biggest tube.
just a thought.
----------------------- EDIT -------------------------------------
FreeEnergy
