HV- voltage multiplier circuit confirmation needed
Started by Steven Dufresne, December 03, 2009, 12:15:07 PM
Steven Dufresne
Hi All,
I'm trying to make a new voltage multiplier board for one of my power supplies so that I can get negative HV from it instead of positive HV. I've attached a drawing of the simple changed circuit that I think will do it below but I'm not an electronics expert. Can someone who knows better tell me if I got it right? Note, I used electron flow instead of conventional current since that's the way I think.
Thanks,
Steve
http://rimstar.org   http://wsminfo.org
PS. It's for my Hyde generator project:
http://rimstar.org/sdenergy/hyde_generator/index.htm
It's basically a big capacitor with rotors and stator in between the plates. Previously I was using HV+ on one plate and ground on the other. I want HV+ on one plate and HV- on the other instead. I'll use separate power supplies for HV+ and HV-, both relative to ground.
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
wings
Quote from: Steven Dufresne on December 03, 2009, 12:15:07 PM
Hi All,
Thanks,
Steve
see here:
http://www.rmcybernetics.com/science/high_voltage/voltage_mult.htm
http://www.celnav.de/hv/hv3.htm
crowclaw
Hi All,
Thanks,
Steve
Hi,
just reverse the diodes... your idea is fine but make sure you limit the output current if you just need the volts!!!
Steven Dufresne
Thanks @wings and @crowclaw! And good idea re limiting the current. I'm not sure if I need just voltage but I may try that too.
-Steve
