0 Members and 39 Guests are viewing this topic.
PaulLowrance
Quote from: k4zep on January 16, 2010, 09:58:27 AM
I agree.  Well I have a pile of normal cores and a few Metglass cores to be here in 3.4 days.  I can easily get more than 1 H with 4-500 turns and appears with a RL network (see JLN's newest video) at a particular voltage you can get that square wave....
Can you show this RL network and how efficient it is. So you're saying one can take a flat loop core, get the current to spike up almost instantly (requires high voltage), followed by flat DC current?
gravityblock
Quote from: PaulLowrance on January 16, 2010, 10:12:39 AM
Can you show the example while using realistic values for the Steorn toroid because I'm getting 1mH for -->
Toroid radius = 3 cm
Turns = 37
Coil radius = 2.5 cm
Permeability = 55,000
Inductance = 985.60 mH
[Edit:]  The above represents a toroid that is 0.5cm in thickness.
Bruce_TPU
Quote from: gravityblock on January 16, 2010, 10:26:27 AM
Turns = 37
Hi GB,
3 centimeters is equal to 1.18 inches, and you have that as the radius of the toroid.  The radius should be 1.5 centimeters or even slightly less.
Please recalculate.
Thank you,
Bruce
gravityblock
Toroid radius = 1.5 cm
Turns = 37
Coil radius = 1.0 cm
Permeability = 168,000
Inductance = 963.38 mH
Bruce_TPU
Hi Paul L.,
Could you please double check the permeability of our Magamps.  The people at Elna mentioned a permeability of 90,000.  You mentioned 1 million.  I tried to find it in the spec sheet but could not.  We need to know this exactly, to know the correct number of winds.   :)
Thank you,
Bruce
