0 Members and 40 Guests are viewing this topic.
0c
Quote from: woopy on January 24, 2010, 01:31:53 PM
the diameter of the core  about 3mm fence wire
Is it a continuous strand of fence wire, or multiple cut strands?
Quotebut the current is about 0.8-0.9 A
Peak or average?
Have you tried recovering the spike energy (flyback)?
Have you tried measuring the available voltage/current in the fence wire?
0c
gravityblock
FINEMET core’s magnetic properties, “B-H curve” can be controlled by applying a magnetic field during annealing.  There are three types of B-H curves with the Finemet cores.
1) H type: a magnetic field is applied in a circumferential direction during annealing.
2) M type: no magnetic field is applied during annealing.
3) L type: a magnetic field is applied vertically to the core plane during annealing.
On page 2 of the Finemet intro PDF brochure, http://www.overunity.com/index.php?action=downloads;sa=downfile&id=362 in regards to the "L type", you will see the Bsat to be 0.57T when the drive field is Hmax=8 A/m while the Bsat is 1.23T when the drive field is Hmax=800 A/m.
There are three types of B-H curve squareness; high, middle,and low remanence ratio corresponding to various applications.  With this material, we'll be dealing with hard disc drive tolerances, does this ring a bell?
It is no mistake.
GB
woopy
Quote from: 0c on January 24, 2010, 01:48:18 PM
Peak or average?
0c
Hi OC
-yes it is a continous wire  (plain) with 3 mm  diameter fence wire
-the voltage go up at the first revolution to about 1 A and than rapidly go down to at max speed 0.78 A. and stay there. (average)
-the kickback spike is only about 40 volts  and i can not light anymore the neon through the 2000volt 1 farad cap as per the previous version. i enclose a picture with only 1 led just for fun.
-I don't see how i can capture the voltage through the core. As you see the core is completely isolated and wounded. Can you be more precise on this point please ?
any propositions for next test ??
thanks
Laurent
Paul-R
Quote from: Jimboot on January 23, 2010, 08:58:18 AM
I'm trying to get my circuit working with a UGN3503 sensor.
For the future, you should note that this device is no longer
being made. I think the replacement is the A1302. (Allegro).
woopy
to OC
ouups
i made my post in your quote
excuse me i am not very used with this forum. But i will improve
good night
Laurent
