TheEnergyDream working PM
Started by teslaalset, December 07, 2009, 10:41:35 AM
BEP
This motor doesn't really amaze me.
What amazes me is folks can look at an obviously well used and worn aluminum plate and declare it painted wood. Why?
Perhaps then they can also declare something under the table surface is providing the energy?
If we are convinced it is fake then why even make a comment? Has anyone looked at the other U-Tube videos by this person? It is obvious he knows something uncommon. Probably not magic or OU but he certainly has a different perspective.
I'll go with the bionic hamster until someone adds a string to the video or he shows the radioactive matches like the plastic lid motor.
Bowmanconsult
Why bother with strings when a continuous blast of air through a nozzle blowing on the magnets will do?
That's the bad thing about this video...they have music piped in so you can't hear the air blowing, nor the sound the magnets would make when he put the magnetic bar on the steel table (assuming the plate was steel).
BUT...if you take a very close look at the spokes of the spinner, you can tell when the RPM's increase as it looks like the wheel spins backwards for a moment or so, and that's natural with spoked wheels.
BUT...if you look when the wheel should be spining at the greatest RPM (right before they take the bar magnet setup away), you don't see that effect. As a matter of fact, it looks like the spinner is decreasing in speed even before they take the magnetic bar away.
That tells me that the person applying the air turned it off before the person holding the magnetic bar took it away. Look at the video several times and see for yourself.
Because there's nothing but close-up shots, we'll probably never know.
One last thing...if the person was really legit (like any of us on this site), wouldn't they go into more detail on how to replicate it?
I'm not a 'dooms-dayer' on perpetual motion, but I feel this is fake.
HMMMM.
gauschor
These videos get annoying with their behavior of "Aww look here! I have invented the real free energy device but I don't explain why and instead play annoying music". Guess what - no one cares about it then. I also have the feeling that the rotor starts moving too early anyways, so the theory of an air nozzle may be correct.
Anyways, I wonder, why people even take their time to create such videos. I don't think it's so much fun for them to take on alternative energy experimenters by a hoax. It's getting old...
EDIT: When looking at this other video http://www.youtube.com/watch?v=yf1IesrHBh0&NR=1&feature=fvwp which seems to function by the same principle? Is there some truth to it? Btw, does anyone recognize how the magnets are glued on the disc? If they are put this way:
______                                 _______
|S____N|_______|axis|_______|N____S|
or that way:
__                                       __
|S|                                      |S|
|  |____________|axis|_______|  |
|N|                                      |N|
Vertical or horizontal?
Edit2: Oh, I forgot: you can even put them sideways
junior_love_2003
Is very obviouse is a trick . A lot of ppl claiming they have find overunity ,is like a MEADNESSS. When you see this kind of muovies please look at the fluent and smooth turning of the rotor . That is perfect movement, something you cant make with magnets(our days ). If you so some real videos with ppl that are trying to make something you will see that magnets are stoping from time to time becouse of the HAOTIC magnetic field. 2nd thing this guy dosent use magnet shielding so at least to say he has a Controled Magnet filed .
   So if you want a simple explenation how that works .
1 The material of the machine dosent meather only  magnets
2 A big transformer underneeth the table or what is he having over there will make the magnet rotor spin smooth becouse of the fluent and orderd magnetic filed produce by the transformer that are spining continuasly. ;)
  So next time make the diference from the 1st view.
stivep
You did not noticed that when he dissemble hid device  -one of the blocks( with holes) is put to lay perpendicularly to another . AT THAT POINT YOU WILL NOTICE THAT THERE IS MAGNETIC FIELD FROM THE BLOCK .iT IS LIKE  BLOCKS ARE MAGNETIZED.The block moves by itself.
