TheEnergyDream working PM
Started by teslaalset, December 07, 2009, 10:41:35 AM
Schpankme
Quote from: stivep on April 04, 2010, 06:35:37 PM
You did not noticed that when he dissemble hid device  -one of the blocks( with holes) is put to lay perpendicularly to another . AT THAT POINT YOU WILL NOTICE THAT THERE IS MAGNETIC FIELD FROM THE BLOCK .iT IS LIKE  BLOCKS ARE MAGNETIZED.The block moves by itself.
IMO - This type of Thread, once found out to be a Hoax, should be deleted.
Schpankme
triffid
BEP
Careful, Triffid.
You may be summarily found to be a hoax and then deleted.
Such decisions are found by mass opinion, are they not?
BEP
Quote from: P-Motion on June 05, 2010, 12:52:52 PM
  Notice the arrangement of the magnets ?
And more. I will try for time to post my analysis later.
Couple of things assumed by evidence on the video: 1. He (he is a he) is probably a retired welder of structural steel. 2. The items he built were probably much smaller and tighter tolerance than buildings. Those things or he is very close to another with that history.
Think I'm full of crap? Identify every item in the video, exactly. No guesses of what the part is or the material. If you can't - you should try another project.
Until you can, you can't debunk the video, either.
BEP
As long as compressed air is said or shown to be used then it is acceptable.
This one implies the motor runs with no energy source but does not say so. So, if he is actually using compressed air then he is a fraud.
Where I have difficulty is when a viewer states that compressed air is being used with no evidence it is. To me, this person is just as much a fraud. The source or energy could be other trickery. Why limit guesses to compressed air?
If I think a device may have merit I'll attempt to disprove what has been shown. If my attempt runs as in the video, with no indication air is the trickery, then I must try harder to disprove it until I have succeeded or failed to disprove it. If I can't disprove it then ... never been that far...
I wish I could find one like that  ;)
If it doesn't run then either there isn't enough information, I didn't understand and follow the information given or I'm too dull witted to replicate the project. In any case I shouldn't have started and I certainly have no right to call anyone names. My failure does not prove anything except my failure.
I see no need for compressed air on this one.
However, I am waiting for the author to show the string. I can't wait to see if he is as good as the last guy. That one had a string running above and below an object at the same time. Forget the motor. That string magic is more interesting  ;D
