TheEnergyDream working PM
Started by teslaalset, December 07, 2009, 10:41:35 AM
Pirate88179
fritznien
right on bill.
i have not seen TK post in a long time, any idea what has become of him? thanks.
fritznien
Pirate88179
Here is a photo I did back then:
Pirate88179
Quoted from Rosphere:
"I went back and  re-watched the backed-up copies of the few videos that Mylow made of his  device operating on the glass table.  I noticed the following  'technical examples' of a probable hoax.  I suspect that there may be a  fishing-line 'pulley string' around the shaft going off-camera to the  left and that the camera resolution is too low to see it.
Regarding video: http://www.youtube.com/watch?v=oAs4-rQXQjU&feature=channel_page
At  1:22 he walks to the back of the table taking the long route around the  right instead of the short route around the left.  (Avoiding the string  to the left.)
At 1:40 he states that he, "wants to make sure  that everything is nice and tight," and that he is going to move the  rotor assembly to the right, (our right,) to make it go faster.  (Adding  tension to the string.)
At 2:24 he walks around the right side of the table again, back to the camera.  (Again, avoiding the string to the left.)
At  2:47 he does a walk-around with the camera.  (The camera work seems a  bit 'bouncy' as he passes by the left side, as if he is stepping over  the string.)
At 5:05 he stands on the glass table, camera in hand pointing down at the device.  Then he starts another clockwise walk around.
At 5:30 his left foot steps over 'something' on the left side of the device.  (The string?)
At  5:32 his right foot steps over 'something' on the left side of the  device.  The rest of the path around the table he shuffles his feet on  the table appearing to step over nothing.
At 5:51 we catch a  quick glimpse of some 'breadbox' sized object sitting on the love seat  in the background on the opposite, (left,) side of the table high enough  where a drive motor might be placed.  (There appear to be wires  connected to the left side of this box and a 'stick' poking out of the  right side, perhaps the switch.)
At 6:50 he again takes the right side path to the back of the table.  (Again, avoiding a potential string on the left.)
At 8:22 he again takes the right side path to return to the camera.  (Again, avoiding a potential string on the left.)
At  9:05 he again takes the longer right side path to the back of the  table, to show his face.  (Again, avoiding a potential string on the  left.)
At 9:25 he again takes the right side path to return to the camera.  (Again, avoiding a potential string on the left.)
Regarding video: http://www.youtube.com/watch?v=uLzh5cibTKE&feature=channel_page
At  0:41 he removes the rotor from the base and holds it to the left side.   (I suspect that the string is still around the shaft between his left  hand and the rotor plate.)
At 0:50~052 he appears to be moving  the string out of the way as he mumbles something about putting, "it  right there," as he touches the left stator support for some strange  reason.  (Whoops.)
At 1:18 he replaces the rotor assembly and  mumbles, "make sure everything is lined up here."  He is looking under  the rotor, for some reason, up until 1:24.
At 1:34 he picks it up and moves it slightly to the right, (taking-up string slack.)  Then he replaces the stator assembly.
At 2:03~2:06 again, he moves the rotor assembly even more to the right, (adding string tension.)
At  2:26 he lets go of the rotor assembly and it starts to spin slowly and  smoothly.  (there appears to be no jerking, (da/dt,) as the ends of the  rotor magnet groups pass under the stator as we have seen in his other  videos.)
At 3:15 he, again, takes the long path around the right  side of the table to move to the back.  (After adjusting the stator  position and not getting any more speed, the rotor seems to be moving  slowly at a steady rate still.)
At 3:22~3:37 he plays with the stator adjustment with no change in speed.
At 3:41 he, again, takes the long right side path around the table back to the camera.
At 3:44 he moves off camera to the left, where the drive motor may be located.
At ~4:10 the rotor seems to be accelerating.  (After some tension adjustment from the motor side.)
At  4:45 he, again, takes the long path around the right side of the table  to the back, avoiding stepping over the string on the left side.
At  6:45 he explains that he, "got this cool little rubber material so this  thing won't slide."  Why would it if, "this stator assembly is being  pulled down?"
At 7:26 he, again, takes the long way around the  right side of the table to get to the left side of the camera.   (Avoiding the string on the left side.)
At 8:20 he does a  walk-around with the camera.  (The camera work seems a bit 'bouncy' as  he passes by the left side, like in the previous video, as if he is  stepping over the string.)
At 8:37 of the walk-around, when he is  on the right side of the table, we can not see high enough in the  background to see that box on the love seat from the previous video, (at  5:51.)
At 9:21, after stopping the device, he moves the rotor assembly to the left.  (To take tension off the string.)
At 9:30 he removes the rotor from the base and holds it to the left side, again, like at the beginning of this video.
At  9:37 he brings the rotor right up to the camera to show the bearing.   (The string must be off the shaft now because we are at the end of the  video and he no longer needs it.)
At 9:52 he quickly replaces the  rotor assembly on the stand, (without taking the extra few seconds that  he needed when he replaced it the first time.)
Regarding video: http://www.youtube.com/watch?v=TkGC8EPKBgg&feature=channel_page
At 0:30 he removes the rotor from the base and holds it to the left side, again, like with the previous videos.
At  0:34 he shows the bearing like at the end of the previous video but he  does not bring the rotor right up to the camera.  (The string is still  attached to the shaft.)
At 1:03 he slides the rotor assembly to the right after replacing it on the base.
At  1:05 he says, "I'm pushing this disk this way," (pointing to the  right,) "so I can be able to get it to go."  (String tension again.)
At  1:45 he says, "for me to get this to go, I'm going to push this this  more that way."  Again, pointing to the right.  Then he does.
At 2:01 he says, "I don't know why this thing's not working."
At 2:27 he says, "I don't know why it's not working," as he looks under the rotor at the shaft, (where the string is attached.)
He  fiddles with it some more and ends the video early, at 3:34, without  success.  (Maybe he got some body oil on the shaft from the end of the  previous video when he took it apart.)
I hope this is enough 'technical examples' to show why I suspect this may be a hoax."
Pirate88179
Quote from: fritznien on August 08, 2010, 03:50:54 PM
right on bill.
fritznien
Thanks.
I have seen him posting some vids on youtube but I have not seen him here for a while.
