TheEnergyDream working PM
Started by teslaalset, December 07, 2009, 10:41:35 AM
bmlobo
Hi All,
Here is a site that I am working on a pulse generator and generator coils for a wind powered setup. Take a look at the pictures and feel free to comment.
http://freepowergeneration.blogspot.com/
Thank you
bmlobo
Hi All,
Thank you
Pirate88179
Bruno:
Nice site.  Very well done.  I am looking forward to seeing your progress.  Nice machine work there too.  I did precision ceramic machining using diamond tooling for over 20 years.
ZaPHoN
I suspect an air line is used or a charged coil outside the frame and this is how I figured it out.
The reference video I am using is http://www.youtube.com/watch?v=u5lXNpOnurw&feature=related
I have analyzed this carefully in Adobe After Effects fame by frame for nearly five hours. I have to admit he was careful to make sure there was no particles that could blow away because what I did was first stabilize sections of the video to so it wasn't bouncing all over the place. Then I carefully watched a few frames at a time to see if any particles moved across the surfaces. I found nothing. This amounted to a lack of evidence of this guy using air specifically so I had to find some other evidence.
Remember, unless manipulated by a coil or other magnets a magnet's force is static. We should be able to assume that when he tunes in his device to get either a steady RPM or an accelerating RPM then the RPM should be predictable unless otherwise manipulated in a fraudulent way.
27 seconds into the video this individual begins to advance the steel bar (Used for clamping by machinists) and the rotor begins to spin.
35 seconds into the video this individual stops advancing the bar and begins advancing the two magnets on the bar to effectively tune in an optimum RPM.
43 seconds the tuning stops and hand is removed.
Now from here on the rotor should either maintain a constant speed or accelerate. But, thanks to temporal sub - sampling we can clearly see that the rotor speeds up then slows down then speeds up again then finally starts slowing down just before this individual stops the rotor with his finger. This is completely in opposition to the way magnets behave. Watch carefully and you will see this.
WilbyInebriated
Quote from: ZaPHoN on September 05, 2010, 10:55:22 PM
some questions for zaphon:
care to demonstrate your suspicions?
can you show a replication being powered by a charged coil outside the frame?
are you suggesting that a rotor with magnets on it being repelled or attracted to a charged coil will speed up, then slow down, speed up again and then slow down again?
