Cure diseases and more with electricity? Has anyone seen this yet?
Started by Mark69, December 07, 2009, 11:54:05 AM
IronHead
Well we first have to understand what plaque does. It is a sealer for the body mostly. Here is the problem. If your body becomes very acidic it will begin to consume itself. These acids will cause cracking and bore holes into the heart and arteries and the plaque comes along and files those injured areas so you do not internally bleed to death. Well if the acid state continues then so does the plaque sealing of the holes and in time will cause a blockage in the arteries and disrupt functions of the heart. In this case you need to get your PH balance proper. There are many ways to do this. Plaque and Cholesterol is not the problem  ACID is !! Remember this, that as you get older you become more acidic and your diet must change with age.
Plaque comes out of the teeth in the presents of Carbohydrates, it takes about 8 hours I think. This is why you suppose to brush you teeth  within every 8 hours of eating or right after you eat. Plaque is really not the problem, it is just the glue that glues together billions of dead bacteria layers in the teeth and where there is dead and sealed oxygen depletion zones there is possible infection.
For your Tonsils consult your dental doctor at this time.
IronHead
Step one , get your teeth cleaned by a dentist.
Now throw away your tooth paste as it is the worst thing you can put into you body , It is a super toxin.
And if it gets into a extraction site it will never go away at least until your body fully decomposes in the grave!!
Get some oil of oregano, mind you this stuff is very hot, like straight cayenne pepper. Next get some liquid Aloe juice from the drug store and some cold press or cold spun Coconut oil. Look on the net you will find it . It can not be heat processed as it will not work. These things are like bacteria sponges , they will suck the living and dead bacteria right out of you rmouth if not concreted in plaque. This is why you should get your teeth professionally cleaned , to open everything up in your mouth.
oil of oregano
wash you hands , dry and put a little bit of oil on your finger and rub the tooth brush in the oil and brush your teeth. Again this stuff is hot, it will take some getting use to.
Aloe  juice
Use like mouth wash for a few minutes but only a small amount about a tsp every time you brush.
Spit it out, you dont want all the dead bacteria in your system
This stuff taste nasty, it will take some getting use to
We will be using this juice in other ways and mixes as well
Coconut oil
Use like mouth wash once every 2 to 3 day about a tsp.
We will be using this oil in other ways and mixes as well
Doing this will also keep these rest of your body just abit healthier.
BTW i am 47 years old and have had only one cavity in my life in a wisdom tooth.
Cap-Z-ro
I have found nothing better than hydrogen peroxide for keeping your teeth plaque free, and your gums healthy.
H/P dissolves the plaque which harbors enamel destroying bacteria.
All the advice given above by IrinH sounds like great advice too.
I would caution people on the various brands of aloe juice though...many have taken to adding a chemical form of 'citric acid'.
The body and citrus fruit supply the body with natural 'citric acid'.
Find out what one of the world's foremost bio-chemists J Hart has to say about the chemical additive 'citric acid'.
coljoe.com
Regards...
nitinnun
http://www.overunity.com/index.php?topic=8499.msg216262#msg216262
the elites are adjusting earths orbit,
to kill most of the population !
they know how to do it,
and they have been planning it for decades !
you need to show this link to other people !
we need to light a fire under their ***es .
blueplanet
Quote from: nitinnun on December 20, 2009, 11:53:43 PM
If my memory serves me well, HAARP is about hurricane manipulation in Cuba. From 2005 onwards, there has been  no significant hurricanes making landfall in the US, thanks to the HAARP technologies.
Please check out this patent before making unsubstantiated claims:
http://www.freepatentsonline.com/y2008/0011500.html
The axis of the earth may be vulnerable to a shift. But this is most likely due to the the fact that too much oil has been extracted from the ground, leaving some parts of the earth hollow and piezoelectrically unstable.
