Cure diseases and more with electricity? Has anyone seen this yet?
Started by Mark69, December 07, 2009, 11:54:05 AM
Mark69
Rosphere
Mark69,
I made one nearly two years ago from information obtained here at this forum.
http://www.overunity.com/index.php?topic=4177.msg79300#msg7930
Good luck,
Rosphere
IronHead
Umm Ok,  for electrical stimulation of the blood. The blood takes 7 minutes to cycle through the body. So for the first 7 minutes pulsing low current 7.8hz charge with two electrodes about an inch apart with wet cotton on the whist at the artery site. Then stop for 7 minutes and repeat to kill viruses and fungus discharged by the bacteria that you killed in the first go around. The relax time or off time of 7 minutes is important to keep these nasties in the blood so you can electrocute them again.
Now this is not going to kill all the nasty critters in the body. Some of them are hiding in places where there is no oxygen (not in the blood). These guys are the anaerobic nasties. So to kill them you need oxygen and a lot of it. One very good method is to use ozone system and saturate your water and drink right away because it only stays in the high oxygen saturation state for about 30 minutes. Also Calcium will double the oxygen levels in the body. Most all people today are Calcium deficient. Now understand when you kill these guys off, they will also release virus and fungus, some of which will get into the blood stream. So you need to do you electric therapy daily. Oh and dont forget you must have good vitamin D levels to break down Calcium into the some 500 chemicals the body processes from Calcium. The D is only to get the process started.
But then there are even more nasties  hiding in the body and protected. For those we need a poison that they can not live in or their protective shell can not live in. but the good cells can. You gotta pop that protection shell open. That poison is Black Walnut Husk that must be from a green living tree. You want to scrap the inside of the bark and make a powder, ingest 200mg of powder for a few days will do the trick. But you better have you liver in good shape for this, as all and I mean ALL of the nasties in your body will be flush into your liver in the first day or two. Your liver will go into toxic shock if it is not healthy. There is a way to flush the liver before you do any of this. It takes about 2 to 3 weeks. Now if anyone is interested in this I will continue on?
Rosphere
Quote from: IronHead on December 19, 2009, 06:26:54 PM
...There is a way to flush the liver as well before you do any of this. It takes about 2 to 3 weeks. Now if anyone is interested in this I will continue on?
Ironhead,
A friend of mine once told me that coffee enemas rejuvenate the liver.
A good place to pause, if this is where you are headed.  Please continue.
Thank you for your 777 tip,
Rosphere
Chad
If you take "Milk Thistle Extract" (sillybum marinium) this is a very impressive in protecting the liver from dangerous toxins, it is use in hospital when people mistakenly eat Death cap type mushrooms that devastate the liver.
Its proven in lots of medical studies to protect the hepatic cells and also help regenerate them so this should benefit you whilst you flush the toxins from the body.
This is turning into one of the better threads. :)
