Mostly Permanent Magnet Motor with minimal Input Power
Started by gotoluc, December 07, 2009, 05:32:38 PM
Khwartz
@ Luc.
My idea of guiding system to place your outside magnets between the steel plates and gluing them. (See attachment).
Added:
Large picture deleted! ^_^
BTW, how you can reduce the picture on a smartphone? :/
Khwartz
Sorry, didn't see any option to reduce the picture when uploading :/
gotoluc
Ron, please do keep up your experiment and share your findings as it is worth more then words.
Khwartz, can you please calculate how much Joule energy it takes at Unity to lift 2.35Kg. 1mm, 2mm and 3mm in 1 second.
Thanks for your time and help
Luc
ADDED
Also, please delete that large pic and reduce it prior to uploading.
I worked all day on my guide system, it's 90% done now, so I would not be open to changes unless it fails.
Thanks
Magluvin
Quote from: i_ron on September 24, 2014, 12:24:40 PM
Thanks for the comeback. Not too clear, would need a diagram.
However, confirmation of the poles shown in the video is if you place a magnet over the energized coil.
In this case I have drawn it inside but can be on any side of the coil... see the N pole locates adjacent
to the N pole of the coil. Now everyone knows like poles repel, right?
So the S pole that the hall sensor indicates on the top inside is present.
OK, I have redone the 'sketch' to better indicate all the block walls present in an air cored
rectangular coil. The external magnet shows the natural attachment direction.
poyntie's  cored solenoid coil is invalid in this discussion as my video is a representation of the polarity
present around a cross section of an air cored coil, which enhances Luc's original diagram, not the whole external field of a solenoid coil, which is a diversion.
Ron
Hey Iron
Below are pics to simulate 1 leg of the coil you used in the vid, showing only 6 wires for simplicity of making the diagram.  ;D But still square like your coil.
These pics depict what you were showing. Just a cutaway of 1 leg of your coil.
More in next post
Mags
Magluvin
This was the alternative orientation of the sensor that I suggested below
More in next post
Mags
