Mostly Permanent Magnet Motor with minimal Input Power
Started by gotoluc, December 07, 2009, 05:32:38 PM
gotoluc
Quote from: microcontroller on April 16, 2012, 02:10:03 AM
Hello Luc i did some experiments along these lines in the late 2005.
It can be as easy as sticking magnets to a modified transformer see below.
These are used is SMPS for noise suppression.
The coil form usually has 4 segments so i cut it into half leaving two segments only, and then it can move over the core due to the created free space.
The coil form you see in the picture is specifically wound the first segment is wound clockwise while the second segment is wound counter clockwise, and i think you can guess what the field looks like when it is energized on a DC current  :)
Hi microcontroller,
thanks for posting your ideas.
I have also tested transformer E cores assembled together and it did not work for me. The problem was there was no movement of the coil.  I have also tested bucking coils and that is the same problem (no movement)
If you are getting it to move please do a short video of it please
Thanks for sharing
Luc
gotoluc
Quote from: Peanutbutter29 on April 16, 2012, 11:04:05 PM
@ gotoluc
I just recently got to watch a good chunk of your videos.  I'm incredibly late, having avoided research for a few years; but Great job with all the work and videos!
That's pretty much it ATM, lol.  Just wanted to say good work!
Thanks Peanutbutter29 for your positive words
Luc
gotoluc
Quote from: hartiberlin on April 17, 2012, 05:41:06 PM
Hi Luc,
you need at least to get 10 times better with your lift to get into the
unity range.
To get conclusive overunity you need to get about15 to 20 times better so you could also close the loop.
So you really need to get much bigger magnets and setups and also much bigger cores.
Size really matters here and this is the case with ALL magnetic setups to get good efficiency and
reduce losses...
Regards, Stefan.
Hi Stefan,
I thought you said if I get the coil to go up to 1.2mm then we are at 100%... but now you say 10 times more which is over 12mm. Which one is it?
Luc
EDIT Okay, I see my error Stefan wrote 1.2cm and thought it was 1.2mm.  We are far off and I don't think I could get it to that using the current build.
DeepCut
Luc asked me to update the spreadsheets to use grammes instead of kg, millimetres instead of metres etc.
New versions are same names so same download links used.
Here is the Microsoft Excel version :
http://internut.webspace.virginmedia.com/Lucmotor%20Efficiency%20Test%20-%20Capacitor%20Version.xls
Here is the Open Office version :
http://internut.webspace.virginmedia.com/Lucmotor%20Efficiency%20Test%20-%20Capacitor%20Version.ods
*** edit add ***
I think they may have downloaded as read-only before but this should be fixed now.
Stupid UNIX file permissions ;+}
All the best,
DC.
Jimboot
@gotoluc thanks mate luvyawork. Just had a play with a Rodin coil and your idea.
http://www.youtube.com/watch?v=Q3Q_1c11wRQ
Edit: link fixed
