Paul Pantone GEET system challenge, by Tommey Reed
Started by Tommey Reed, December 07, 2009, 06:05:02 PM
Tommey Reed
I have looked in to what Paul Pantone claims of plasma reaction to run his engine off of pickel juice and window cleaner....
This is my challenge video's...
http://www.youtube.com/user/OverUnityNow1#p/a/u/1/nmLb_jYXB38
Tom...
l_hester2003
Hi Tommy
I also have researched a few heated rod carburetor designs. Two of them were over20 years ago (before Pantones claims)  I was intrested in the claims of magnetic materials and heat being able to transmutate water (or bbq sauce) into fuel.  My tests with the free plans were identical to yours. NON PRODUCTIVE!
  GEET provoked me to investigate further, just to see if I could actually introduce a measureable amount of water into a gas engine, if so test the emissions and output.  My video showe's a very altered bubblier, although the geet is UN-altered. I was able to introduce approximately 60%gasoline to 40%  water.  It was easy to detect gasoline fumes, by smell , and carbon at about 5 to 10 feet with a detector. Longer run times were due to less fuel introduced via vapors. On a cold day I was able to recover the same amount of water from the exhaust that I started with, with this  I only suggest that I was removing most of the heat through the exhaust.  I received the usual hate mail, and of course have seen many on the yahoo group make the free plans and announce compleat success, just to see them later quietly leave the group.
  I invite you to watch my video on youtube lhester2003 search vortex heat exchanger.  Please take time to read the post from me on this video. I am not very computer savvy or I would provide a link like you did with your video.
Thanks
Leonard Hester
Tommey Reed
Thank you, you're right. I may not be an engineer, but I do know how energy is converted.
I have made these test to prove what you just said.
The Geet system is a scam, no plasma, nothing special other then a heated vapor carb.
Add your finding video to my geet challenge videos..
Tom..
itanimuLLi
Hey Tommey U cold use your bubbler  to evaporate used oils that contains a lot of hydrocarbons to burnt in the engine. Just add some gasoline or a solvent and off  U go, saving money and environment.
