human "consciousness", is made of frequency.
Started by nitinnun, December 07, 2009, 09:21:48 PM
nitinnun
in the same way that a lego boat, is made of dozzens of lego bricks.
the human nervous system, runs on electricity.
the electricity in the human nervous system,
is what holds frequency/consciousness in the body.
the more active someones nervous system is,
the more frequency/consciousness can be held in that persons body.
just as the larger a capacitors capacity is, the more charge it can hold.
matter/atoms, can store frequency.
the heavier the element, the longer the element can hold frequency.
the dirt and stone of the earth, can hold frequency/consciousness, for hundreds of years.
if a large, violent battle happens in a field,
than that field can hold the rotten negative energy of that event, for centuries.
the calcium and minerals in the bones of the human body, store much of a persons memories.
in the same way that the calcium and minerals in the ground, hold frequency in the ground.
negative magnetism from paramagnetic substances (sand and stone),
seems to have bad effects on life.
positive magnetism from diamagnetic substances (water, copper, silver, gold, busmuth),
seem to have good effects on life.
because negative magnetism and positive magnetism,
are capable of influencing frequency.
i strongly suspect,
that a humans logical left brain, holds most of the negative magnetism in their body,
and their creative right brain, holds most of the positive magnetism in their body.
exactly like a capacitor.
and that frequency/consciousness, shifts between the left brain and right brain.
that frequency dips into both brains, like a punch bowl.
and that the stronger the left and right halves of the brain are,
the stronger the frequency signal is,
the more conscious that human is,
the more that human can accomplish.
most humans do not even use 25% of their brain.
i use about 75% of my brain.
mainly because i have spent most of my life calmly sitting and thinking.
in a monk-like manner.
i went into my mind whenever possible.
to deeply contemplate things.
and to find my own answer, from within my awareness.
not from outside of my awareness.
in the boring, limited physical world around me.
you may have whatever opinion you wish, regarding my posts.
but i ask that you use whatever constructiveness you find in my posts,
to make your life better, than it currently is.
jikwan
very interesting nit
confirming all my suspicions/perceptions
lets have some more of this!
got anything else?
zen is the art of seeing everything and noticing nothing
nitinnun
i do.
every life form that has a nervous system, has a DC magnetic field surrounding its body.
this DC magnetic field, is generated by the life forms nervous system.
some people call this DC magnetic field the "aura".
and some of the right brain dominant humans seem to be able to sense its presence.
even if they have mis-labeled it as mysticism.
most thinking does not happen in the brain.
it happens in this "aura".
the brain merely adds details and subroutines, to the thoughts in the "aura".
the brain and spinal cord are both shaped like a large antennae, for magnetism.
because that is the nervous systems function.
to be an antenna, for your "aura".
along this antennae, there are 7 "chakra's".
or clockwise/counter-clockwise spinning vortexes of magnetism.
the spinning of these chakra's, allows each chakra to hold and process frequency/consciousness.
the chakra's absorb whatever frequency is around them.
so your root chakra absorbs 60 hertz electronic pollution, which causes the nastier elements of your root chakra to become aggravated.
such as fear, anger, and materialism.
the illuminati types know that 60 hertz radiation forces us to think and feel those things.
they want us to think and feel those things.
because they know how to profit off of all those things.
in one way or another.
when you stand on the negative/paramagnetic ground,
and the positive/diamagnetic sunlight is shining on your head,
than electrons are attracted from your feet, into your head.
this recharges your aura.
so that your nervous system can send the electrons from your brain down to your feet.
with the nervous systems normal function.
the south pole of this planet is positive.
the north pole of this planet is negative.
if you sleep head facing south, and feet facing north,
than the earths poles will recharge your nervous system.
and you will feel great as you sleep.
if you sleep head facing north and feet facing south,
than you will feel very dizzy and very uncomfortable.
because the earths magnetism,
is PREVENTING the electrons from slowing from your feet,
back into your brain.
when i faced head north and feet south, i felt like i was being held up side down.
while dangling over the edge of a 50 story tall building.
from a rope that was tied around my leg......
if your bare feet touch the earth, and your bare head touches the sunlight,
electrons can properly flow from your feet to your head.
but if you wear shoes on your feet, lenz law takes place.
the negative ground makes your feel positive.
which attracts electrons into your feet, and away from your brain.
and KEEPS the electrons in your feet.
wearing shoes while standing on the earth, is one of the dumbest things that mankind does.
it directly disrupts the human nervous system.
to fix this, i have a copper foil plate sitting under my computer desk.
my copper foil plate, is electrically grounded to the dirt outside.
VIA a wire that runs from the plate, through a small hole in my window frame, into the dirt.
when i place both of my feet on my copper plate, i am grounded.
and i swear that i feel a vague benefit from it.
a similar thing likely happens, if the human wears a hat.
the hat prevents positive sunlight from touching their head.
causing the head to become negative, through lenz law.
pushing electrons out of their brain.
jikwan
youre right, man
also whenever a person faces south they are stronger
this is a scientific fact
ive always made an effort to lie down head pointing south
sitting/working etc
i read in some ancient volume about red indians of old used to
wear pants with a flap on the backside of their pants
they valued contact with earth so much that when they sat
they pulled down the flap and sat directly on earth
this makes you think
years ago i made some enqiry into what frequency they were
transmitting television
seems they are able to do this-alpha/beta/theta etc
they transmit it on a certain band which relaxes you and you
are in the optimum suggestive mode
then they can programme you anything they want
the 60 hertz ive not come across before but sthing tells me its a real thing
going to go through your topics/posts-particularly water polarity
