Request - A simple circuit to recycle flyback in a pulse motor.
Started by interestedinou, December 22, 2009, 06:22:47 AM
luishan
Check it out this video. And Watch all related videos(Pulse motor).
http://www.youtube.com/watch?v=LNoZ9DpUc4s&playnext_from=TL&videos=6h5yKaRsuGI
He make a high voltage to feed back to coil.
But I could not figure it out. How to hook up his set-up.
I asked the circuit diagram for the setup. But he reply me a message as below.
"Sorry i dont have time to draw a schematic right now but I can tell you that the circuit is quite simple and basic. I run the positive to the drive coil first . On the ground side of the coil I place a diode and feed it back to the positive side of coil. Then I turn the coil off and on with a relay on the ground side ,you must use capacitors connected to the relay points the radiant spikes are very powerful and will burn points , you must use large relay also or you will burn points. The relay is turned on by using a small pick up coil neer the passing magnets connected to a transistor which you connect to the small coil on the relay which pulls it in to turn it on.I also placed a 1k ohm pot on the ground side to the transistor to help control on time.Hope this helps you get started.
john U."
Anyone help me figure it out how to setup or hook up his pulse motor.
Thank you. :)
jadaro2600
Seems like a diode is the best option for converting fly back to the coil.
guruji
Ted can one use that to a bedini motor. If yes can you show how to connect that circuit with the SSG bedini please?
Thanks
tishatang
concepts explained here by hoptoads:  Maybe this will answer some of your questions?
http://www.totallyamped.net/adams/index.html
tishatang
guruji
Hi guys would this circuit works as Ted exclaimed?
Thanks
