New running gravity wheel demo video
Started by hartiberlin, December 29, 2009, 09:02:18 PM
mr_bojangles
look at the axle, when it switches to the second angle you can see another wheel connected to the axle...what is that doing?
from the front angle it looks like its just hanging there, but after watching you will see it spins and doesn't appear to have a purpose, its just connected to the axle spinning
why would that be on there?
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
ekko
I think there are many gravity wheels now today that could work.
The important conditions are : that you have an unbalanced wheel AND that the acceleration of the up-going mass is bigger than the acceleration of gravity....
No way the mass could be lifted against the force of gravity if it has very little acceleration!
So the wheel needs a starting-speed to overcome gravity.
What we could learn from this guy is that it is very clever to bring the wheel up to the correct speed before aspecting some result.
Some disagree ?
I think Abeling mentioned this also.., no ?
ekko
Mmm ;D sorry, i looked at another movie that was linked to this one in youtube.
What i tried to point out is that some gravity wheel only starts working when there is an initial speed, making it possible for the unbalanced wheel to build up some netto acceleration.
I think sometimes its is necessary to start the wheel with a motor and as the wheel is building up every rotation some extra energy from gravity, at one point the motor is not longer needed, but can be used as a generator.
ekko
Regarding this wheel in the video:
Its like the guy is shifting the direction of the centripetal force with the weight at the little wheel.
Normally in a rotational movement the centripetal force is always directed to the center forcing the mass to make a rotation.
How does he do this? It takes a lot of energy to change the direction of the centripetal force from a rotating mass.
Is the netto-acceleration from the wheel put back into the inner wheel ? I dont now.
