New magnet powered perpetual motion machine
Started by hartiberlin, January 01, 2010, 09:18:36 PM
forest
I believe it may work that way.
The solution was always to combine two forces : gravity and magnetism.This is the implementation of that idea and that's why I believe it's real.
Staffman
According to the original poster of this video, there are supposed to be magnets on the guillotine parts. If you look closely at the video, you will notice that the pendulum is pushed away from the guillotine as the guillotine slides down. The speed of the guillotine sliding down is a little suspicious to me.
norman6538
First off I see an upper set of repeling magnets and a lower set of repeling magnets
at the gillotine. The pendulum arm at the top pushes the gillotine off balance so that
the gillotine with its repeling magnet drops and gives a tap to the swinging pendulum.
Then when it moves away the upper repeling magnet drops and resets the gilotine to
its up position. The weight, and magnetic forces and leverages of this would all have to be balance correctly. The gillotine trick is that it is in a track so it will not push away but
taps the swinging pendulum to keep it moving.
Very clever I'd say.
I do not quite understand what might be at the top above the pivot - maybe just
pendulum balances....
Norman
mike-ao
Quote from: Staffman on January 03, 2010, 12:49:41 PMThe speed of the guillotine sliding down is a little suspicious to me.
i hope i can describe it an undersandable way.
the repel-kick given on the birdpecker-magnets loosen the string where the guillotine is hanging. when the string is loose, it will take a time before the guillotine starts to fall down because of gravity. at this moment the pendulum is still slowly moving toward the guillotine-magnets. the repell-force from pendulum and guillotine-magnets works like a brake for the free falling guillotine, until the pendulum reverses the direction. the guillotine-magnet itself transfer the falling power (weight) trought the repell-force of the magnets to the pendulum-magnets.
sorry about this bad english.
mike
ramset
Mike
You think you could build one of these??
Or explain how?
Chet
Thanks Grandma
