Experiments designing a BLDC Acyclical Generator
Started by leeanderthal, January 02, 2010, 07:55:06 PM
phoneboy
@ magluvin, just a suggestion about needing the copper or magnets to move, I believe if you orient the domains of the magnets you can rotate the field without having to rotate the magnets or coils you are using to generate.
nueview
this is just a thought but if a solid core can be energized such as a horseshoe bar and a shunt bar is placed north south and the coil about the horseshoe is watched with an oscilloscope would this be enough to trap the magnetic value at one moment in time and when opening the shunt give a pulse that would be valued against another moment in time for the magnetic field movement.
just a thought.
Martin
Magluvin
Phoneboy
The theory is that magnet only distort the fields that are everywhere already.  If the copper is still and a disk magnet is spun above the copper, the field lines going through the disc are still and are not cutting the copper. but if the copper spins, then the lines are cutting the copper creating current. and finally, mount the magnet to the copper an move it as a whole and the fields cut the copper creating current.
Strange aint it?
Mags
phoneboy
Magluvin
Phoneboy
Oh, well im not sure what is happening there.
What is the pane? Copper?  Where are the contacts?
Is this your own design?  Looks like something, but I cannot determine what is exactly happening.
As Glenn Beck would say  "Call Me"   =]  geddit  phoneboy
Mags
