Hairpin Project
Started by resonanceman, January 02, 2010, 09:20:03 PM
resonanceman
Quote from: onthecuttingedge2005 on January 02, 2010, 10:55:53 PM
what you really want is a tuned system that directly taps each electrons wavelength and frequency directly but of course this is playing with 'nano' tuning systems that really don't exist yet.
just rember you heard it from me when this type system becomes available in the future. every electron gives of a field of a specific wavelength and frequency, far below the macro scale.
we are talking about trillions of nano recievers that tap directly off the electron itself.
Jerry 8)
Jerry
I remember  someone  testing  an array of diodes.
It seems that  just an array of diodes will produce a small  amount of  usable  energy from quantum vibration alone.
The problem with larger applications  of this is  no chip maker will make  a large scale array of diodes.
gary
gary
Magluvin
Resonanceman
Hi   Are you saying that obtaining amplifying effects of radiant energy can be done at lower freq and lower voltages?
That would be great
Mags
forest
Radiant energy is magnetic wave supported by Earth magnetosphere. :P Simple
resonanceman
Quote from: Magluvin on January 03, 2010, 10:50:04 AM
Resonanceman
That would be great
Mags
I had  a major Ah Ha moment in the first minutes of this video
http://www.youtube.com/watch?v=64yKW9FSsBY&feature=related
There is  a completely different kind of configuration and a completely  different  kind  of resonance than we currently use.
This  configuration and type  of resonance  has been  almost been  completely  forgotten  or  suppressed.
Tesla knew about it, and used it.
If we can fill in enough  blanks  about  the details  of  these things  I  think  we will  be able to bring  back  some of what was lost when Tesla was blacklisted.
I  think that finding  the right configuration is key.
Like  any electronics  circuit  if we do  not  understand what  it is doing  and put it together wrong......it will not  work right.
As far as low voltage goes.
I do think with the right circuits we should be able top make radiant energy  with  low voltage .........of course  it is much easier  to notice what is  going on when  you use higher voltage .....I think this is one  of the keys  to Teslas progress ............he did  things in a big way....... extreme frequency and voltage ......
For frequency ........ as I understand  it  the frequency is not that important ....... yes  a  higher  frequency means more spikes......more spikes mean more power  available........but the  real trick is in  creating spikes with a VERY high rate of change.
I am certain that  information about  energy that would allow us energy independance  has been withheld from us.
In  the first Eric Dollard video
http://www.youtube.com/watch?v=YhuSn6sc7sc
He talks about a man that transmited  a signal between 2 kites
many  years ago ........ this  was  true free energy.
The wind passing  over the kite created  a static charge .......the static sharge could then be temporaly  grounded by the telagraph key
This  produced electrostatic pulses that were picked up by a galvanometer hooked to another kite miles away.
Air moving over  the surface of a kite .........and  air moving  over the surface of water droplets ........ same  effect ......one was used for transmitting  a signal........the other  is what creates lighting.
gary
Magluvin
Resman
I see what you saw in vid 2 about the resonances in a coil. I didnt quite catch that the first time around.
Thanks for pointing it out.
I have to watch all those vids again.
The one where Chris talks about transformer cores, I wish he had given an answer to that. I dont get it.
Thanks Resman
Mags
